Question about JVC DR-MH30S DVD Recorder
Not responding after flashing "loading" for 1 minute then get message R-Lk --:-- on display
Hi I hope someone can tell me whats wrong with my machine. We had a blackout and since when i plug the HDD in the power outlet i get flashing bluelight and the word "loading" flashing on the front of the lcd display. Then after about a minute the lights turn off and the lcd shows " R-Lk -:-- " without flashing or lit up. It remains liek that while the plug is in the power outlet. Any suggestions about what couls hav ehappened. Does that code mean anything. Thanks in adavnce
  • tutunkhamun Feb 02, 2008
    Hi i fixed the problem myself . Thanks
  • Lochside26 Feb 03, 2008
    I am having a similar problem. After a power cut my DR-MH30S displays "Loading" continuously. None of the buttons work and nothing else happens.
  • 4 Answers
Hard drive issue or power supply. Power supply prone to bad capacitors (look for leakage/swollen tops)
If hard drive faulty you'll need a new one which is no small task. Disk contains firmware and custom file system and smallest I've got image is 10.7gig
Posted on Mar 09, 2008
I have a bwm 50 washing machine displaying e2
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing
Hope this helps
Bob
Jan 12, 2015 | Washing Machines
DELAYED 2 HOUR KEEPS FLASHING NO CYCLES WILL RESPOND
please give the brand so its easy to tell whats wrong, this machine will display any codes?
Dec 03, 2014 | Washing Machines
The buzzer sounds and the rinses indicator light flashes and the programme sequence display " - - - " appears in the display. This occurs at the end of all programmes just as it starts to spin.
Hi - I will tell you whats wrong with the machine, but you will need to get someone familiar with Miele equipment to fix it for you.
On this particular series - Rinse LED flashing means 3 - 4 things could be wrong with the washer.
Tacho - generator is faulty
Drive fault - electrical problem
Motor - has issues with starting
Blockage - drains - drive unit
Restrictions - of the drum turning.
Electronics - may be a component with an intermittent failure/decay.
It would be either one of the above or a combination of 1 or the other...
Jun 20, 2011 | Miele W435WPS Front Load Washer
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
Sep 25, 2017 | LG WM2277H Front Load Washer
My washer stops about half-way through the cycle and displays an "02 F" message. I have to pause, then restart in order to complete the cycle. It sometimes does this twice per cycle. Any ideas what could...
This is the problem below.
F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
www.appliancehelponline.com
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Got an f 02 message, now the door is locked and will not open. Have unplugged and then plugged in again, still locked and cannot unlock and need to get clothes out. What is an F 02 error?
F01 refers to Long Drain Error.
Reason -
Long Drain
What Needs to be Done -
* Check the drain hose
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 13, 2009 | Kenmore Elite 45986 Front Load Washer
Calypso Washer is not washing clothes or spinning; getting LF error message. Water is going into the machine but no washing action.
Hi There
I'm Sending you the fault codes. Hope this helps you and get you in the right direction.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Frequent hard disk failure
check your hard disk cable first and replace it.if this isn' stopin your problem then make a new bios flash. may be ypur bios is reporting your hdd wrong so make a new one. if even after this you can not stoping your problem bay another mb.
Apr 05, 2009 | Intel D945GNT Motherboard
LK ON on display
I had to call customer service to find this out: press and hold the stop and power buttons at the same time. A lk Off message will appear and everything should be fine.
Hope this helps.
Dec 14, 2007 | Panasonic DMR-ES20EG DVD Recorder
JVC DR-MH30S DVD Recorder Logo
200 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
