Question about Intel Pentium 4 3GHz 512/800 CPU processor - SL6WK
No sound device
Hi, i hope you can help me with my problem
the time before i reformat my computer, my speaker is functioning/'working. but after i reformat my computer, suddenly, there is no sound....i tried to play a downloaded song, but a message comes out saying that there is no sound device installed. What can i do? how can i install sound device? can i find it free from the internet? what site? thankyou very much
  • 749 Answers
I need to know the brand of the motherboard and its model/code number or model... then i'll know what sound driver is appropriate to your computer...
I'll wait.
Posted on Feb 02, 2008
I had reformat my PC .. because it wasn't working out .. i was not able to save all the drivers .. as in ALL .. when i finished reformatting my PC .. I discovered that it had no sounds at all .. My PC is...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 13, 2011 | Computers & Internet
I recently had to reformat my computer back to factory standards. I had the Logitech Laptop Speakers Z205 b4 this & they worked.After i reformatted now i only get volume out of my laptop built in...
if you are having problems with your sound
also
hope this helps
Mar 31, 2011 | Logitech Laptop Speaker Z205 2 Speakers
Hi! i don't know what to do with my CREATIVE SPEAKER MF1580. it has no sounds. my cousin reformat my computer. I don't have any driver or installer that can help me to solve the problem. I'm very...
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 11, 2011 | Computers & Internet
I had to reformat my pc and i dont know how to get drivers for sound.Where do i go to download them?
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 05, 2010 | Kinyo UC270B 2 Speakers
My speakers worked , until i reformatted my windows XP computer. now the speakers are not being detected. the lights are on but nothing is working . please help
Hi, you need to check for problems with your sound driver. To do this go to start, control panal, system, then hardware and finally device manager. If there is a problem your audio device will be highlighted with a yellow ?. You will need to down load and install the latest sound driver for your system. If you are not sure which one; you can do a google search, or try the Realtek AC'97 sound driver, which is free to down load from a google search.
Hope this helps.
Aug 13, 2010 | Logitech LS-21 2.1 Speakers
My son had to reformat his computer and lost the
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' theAudio Drivers Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find Hardware and Sound, open the program an select, Audio Devices, and Sound Themes” selectPlayback” click on the Active "Speakers.” to open Configure to: Audio channels. The Speaker Setup "wizard help you with the instructions to fix the sound. Select (Test) click, Next! Part (2) Click 'Properties' and change the "sound"(Level). You can also make adjustments using the Enhancements option. “The (Advanced), “I do not recommended!” Next, in the Controller Information (block), open the Properties Icon to "update" Drivers. Check to see if Device usage: is (enable) if not? Enable it. *Note: Click "Apply, OK, and Save when finished. Restart the computer to finalize the changes. "Rating the solution on its helpfulness is appreciated, thanks"
May 14, 2010 | Audio Players & Recorders
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
Apr 15, 2010 | Logitech X-240 Computer Speakers
Reformatted Computer. No Sound.
Looks like you haven't installed your audio drivers.
Dec 27, 2009 | Logitech X-240 Computer Speakers
I recently had to reformat my computer, and I don't have the software to reinstall the logitech program or whatever. Is there any way to get these working? the sound card is already installed in the...
Follow the procedure for speaker installation here. Verify it.
As this is a very basic output device, it uses the computer's Audio drivers to channel the sound from each speaker correctly. Make sure that your audio driver is installed and working. Other wise open another ticket and give us info on the sound card
Sep 02, 2009 | Logitech X-530 Computer Speakers
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
I have an Fujitsu Siemens Amilo D7830. I was updating chipsets to the laptop when it bluescreened. I had to reformat the HDD and reinstalled Windows Xp Pro SP2. Since then I have installed every conceivable Windows Update file there is and have updated all other drivers and chipsets. However, my soundcard is no longer working.
When clicking on the device in question in the device management screen, the following error messages are displayed for the Realtek AC'97 soundcard: This device cannot start. (Code 10), PCI bus 0, device 31, function 5.
I have attempted at downloading and installing almost every drive I can find for this device, and have followed the standard Microsoft help routines. i.e. uninstalling the device and reinstalling the device still with no luck.
I hope you will be able to assist, as my last resort will be to take it into the a techie shop i.e. PC World for them to have a look at it.
Kind regards,
Sean
Sep 28, 2008 | Audio Players & Recorders
Computers & Internet Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
