Question about Linksys Wireless-G WET54G 802.11g/b (WET54GSUK) Wireless Bridge
Unable to get my WET54G up and running
I had a wireless router whose IP config is:
address: 192.168.1.1
net mask: 255.255.255.0
security: WEP 128 bits
key 1: X... [13 characters long)
I am trying to connect my PC/Linux to the Internet. I have plugged the WET54G to the PC through Ethernet.
IP address: 192.168.1.35
default gateway: 192.168.1.1
When trying to setup the security on the bridge, I do not know where to type the key: passphrase or key 1?
My PC setup is:
IP address: 192.168.1.33
Any idea? Thanks in advance.
    Problem Solver:
  • 6 Answers
How To install on a Lynksys router.
ok on every router there is a ip address range in wich it makes up the addresses, for instance on my wrt300n the ranges are 192.168.1.100 - 192.168.1.199, You can view this by going to your routers page 192.168.1.1 and viewing the SETUP tap and BASIC SETUP subtap and look at Network Address Server Settings DHCP, in order to get the wet54g to work you have to be within that range.
note: if you cant find the ip address range of your router and you have another pc running on wireless go on that machine and run start menu, run then cmd, once there type ipconfig /all and it will show you the ip address of that machine ex 192.168.1.102, this will give you an idea on were to set your bridges ip address, i just set mine at 192.168.1.103 wich was 1 above my other pc
So with that said in your router function 192.168.1.1 make sure you have DHCP enabled and i have my SSID broadcast on and i use wep 128 bit with a passphrase and firewall protection on
BRIDGE: when first installing the wet54g make sure to use it on the pc that the router is hooked up next to because you need to hardline the wet54g right into the router to first set it up. log into your bridge for the first time at 192.168.1.226 username: admin, password: admin, change the ip address of the bridge from 192.168.1.226 to 192.168.1.xxx (within the routers ip address range as stated earlier on my machine i made it 192.168.1.103) and leave it as a static ip address. so it should look like this
Static ip address
IP address: 192.168.1.103
Subnet mask: 255.255.255.0
Gateway: 192.168.1.1 (this is your router ip address)
and from here you should be able to do a site surver and see your router, click on the SSID name of your router example linksys and it should prompt for your security settings if not there on the main page. i used wep 128 bit on infrastructure mode. so make sure its under your correct mode (dont worry about channel if using infrastructure) make sure your security is enabled or disabled depending on your set up, if enabled click on the edit security settings button put in your right mode (wep for me) make sure the Transmision key is the same on your router wich you can find at 192.168.1.1 under wireless and wirless security(mine was transmission key 1). so enter your passphase and generate it appy and close.
apply all of your settings and wiat 15 sec for the bridge to reboot, then go to the advanced tap of the bridge and it should look like this
TransmissionRate : AUTO
Authentication Type: Shared (if using security)
Clooning mode i set to Enable and auto
This should be it for the bridge, now go to the pc your going to be using it on and view your network connections and properties of your NIC/network card and highlight TCP/IP setters and click properties of that make it the following
check Obtain an IP address automatically
and check Use the Following DNS server addresses:
Preferred DNS server: 192.168.1.xxx (make the xxx to whatever you assigned your bridges ip address to, in my case it was 192.168.1.103)
Alternate DNS server: 192.168.1.1 (make your router's IP address )
save and close settings
you should now be able to see the internet.
i tried my best to fully explain this if i left something out i apologize
Posted on Oct 09, 2008
  • 4 Answers
Make sure that you routers IP range is setup to handle the IP address of your PC.
Posted on Feb 04, 2008
How do I enter the WEP encryption on my router
Configuring WEP:
1.Connect a computer to any one of the four LAN ports of the Belkin wireless router.
2.Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
3.Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
4.Click Security under Wireless menu.
5.Under Security, Select 64 bit WEP (or 128 bit WEP).
6.Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
7.Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Jul 23, 2009 | Belkin (F5D7230-4) Router (587009)
Tip
How to setup WEP on a Belkin N1 Wireless Router F5D8231-4 v5000 1. Log into the...
1. Log into the router. To do this you will need to open your web browser and enter http://192.168.2.1
Note If you change the default IP address then you will need that address to log into the router. Normally it is the Gateway IP. You can check this by opening CMD via the Run command window. Once it is open then type ipconfig and hit enter.
2. Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
3. Next you will click on the Wireless heading then Security in the left hand column.
4. Select “128-bit WEP” or “64-bit WEP” from the drop-down menu.
5. Next you can enter your WEP key manually by typing in the hex values in the space provided, or you can type a passphrase in the “PassPhrase” field and click “Generate” to create a WEP key from the passphrase. Click “Apply Changes” to finish.
Note a hexadecimal key is a mixture of numbers and letters from A–F and 0–9. 64-bit keys are 10 digits long and can be divided into five two-digit numbers. 128-bit keys are 26 digits long and can be divided into 13 two-digit numbers.
At this point you should have your WEP setup. When you connect your computer to the wireless router you will be prompt for the WEP key you just set up.
on Mar 25, 2010 | Belkin (F5D8231-4) Wireless Router...
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Wep
WEP
  1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
  2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
  3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
  4. Click Security under Wireless menu
  5. Under Security, Select 64 bit WEP (or 128 bit WEP).
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
  7. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Configuring WPA-PSK Encryption:
  4. Click Security under Wireless menu.
  5. Under Security Mode, select WPA/WPA2-personal (PSK)
  6. Select WPA2-PSK as your Authentication
  7. Select AES as the Encryption Technique.
  8. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
  9. Click Apply changes to save the settings
    Jun 04, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
    I dunno ow to secure my connection with my edimax router
    You can read more about WEP and WPA in the following links:
    This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
    Note:
    • You can configure WEP or WPA. But you cannot enable both at the same time.
    • You can configure Access list and also enable WEP or WPA for additional security.
    • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
    • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
    Configuring WEP:
    1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
    2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
      The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
    4. Under Security Options, Select WEP (Wired Equivalent Privacy)
    5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
    6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
    Apr 27, 2009 | NetGear WGT624 Wireless Router
    Making a wrt54gc wireless router work with a wet54g bridge
    You shouldn't have to enter your SSID unless you have it hidden. Also, make sure you have the correct encryption set on both sides. WEP/WPA/WPA-2 for the Security type and TKIP/AES for the Encryption type. They need to match your router.
    Also, you need ot make sure you are entering the correct IP/gateway/subnet mask address or have DHCP enabled.
    Good luck
    Jan 29, 2009 | Linksys : WET54G Wireless-G Ethernet...
    Unsecured net work
    Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
    Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
    Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
    /regards
    Teis
    Was this solution helpful? Show your Appreciation by rating it:
    Nov 30, 2008 | Belkin (F5D7230-4) Router (587009)
    D-Link AirPlus Xtreme G DI-624
    Using the Configuration Menu
    Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
     Open the web browser
     Type in the IP Address of
    the Router (http://192.168.0.1)
    12 Type admin in the User Name field
    Leave the Password blank
    Click OK
    Home > Wizard
    The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
    These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
    .13
    Using the Configuration Menu (continued)
    Home > Wireless
    Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
    SSID-
    Channel-
    6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
    WEP-
    Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
    WEP Encryption-
    Select the level of encryption desired: 64-bit, or 128-bit.
    Key Type-
    Select HEX or ASCII.
    Keys 1-4-
    Input up to 4 WEP keys; select the one you wish to use.14
    Home > WAN > Dynamic IP Address
    DI-754
    Dynamic
    IP Address-
    Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
    Host Name-
    The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
    MAC Address-
    The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
    Clone
    MAC Address-
    The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
    Enter a DNS Address if you do not wish to use the one provided by your ISP.
    Primary/
    Secondary DNS Address-
    MTU-
    Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
    Home > WAN > Static IP Address
    Static IP Address-
    Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
    IP Address-
    Input the public IP Address provided by your ISP.
    Subnet Mask-
    Input your Subnet mask. (All devices in the network must have the same subnet mask.)
    ISP
    Gateway Address-
    Input the public IP address of the ISP to which you are connecting.
    Primary
    DNS Address-
    Input the primary DNS (Domain Name Server) IP address provided by your ISP.
    Secondary
    DNS Address-
    This is optional.
    Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Secured networking
    Configuring WEP:
    3. Click Wireless Settings under Setup menu.
    NETGEAR Router WEP
    Hope that helps.....
    Jul 06, 2008 | NetGear WGR614 Wireless Router
    Secure my router.
    Configuring WEP:
    Jun 13, 2008 | Belkin (F5D7230-4) Router (587009)
    Linksys Wireless-G WET54G 802.11g/b (WET54GSUK) Wireless Bridge Logo
    1,409 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
