Panasonic TV Remote
Having a problem with the ON/OFF button on my Remote for Panasonic TH-37PE50B. I have to press very hard and wiggle it for it to 'catch' . Otherwise it works fine. Is it OK just to unscrew and open? I was worried all the keys might fall out!
  • tedl Feb 04, 2008
    Taken the screws out but still can't open the thing. Any ideas?
Here's what I did that worked pretty well without any damage to the remote (Panasonic N2QAYB000221)... Once you take out the screws the top piece should be a little loose near the front of the remote. Take a flat head screwdriver and wegde it between the top and bottom half and work your way to the rear of the remote; as you move backwards, you should release the brackets. Once you have released one side of the remote, you should be able to work the other side free. Hope this helps!
Posted on Sep 25, 2010
I just got mine open, took out the batteries and two small screws in battery compartment. there are 4 snap brackets on each side. I stared at the bottom with a sharp knife and made quite a few scratches finished it with a butter knife. Tricky but manage without breaking the plastic lugs. Cleaned the circuit board with acetone, snapped back together and hey ho... hopefully it will work, until the next covering of hot chocolate
Posted on Nov 10, 2014
  • Lisa Rose
    Lisa Rose Nov 10, 2014
    that should read started at the bottom not stared
Just opened one. Just like you said, it has to snap. On this remote (Panasonic n2qayb ...) you have to find a way to pry the botten part away from the top. It is next to impossible to do without scratching the sides, so expect some damage. I broke two (actually one and a half) of the holding 'brackets". It snapped back ok and it's pretty solid again. Did a Panasonic DECT phone some weeks ago, that was a breeze compared to this. (dropped it in the toilet, and it was quite waterproof I must say). Will put some pictures up on a blog, I was really hoping for some to help me.
Reagards, lucas
Posted on Dec 14, 2009
  • tugnutt831 Sep 25, 2010
    Genius:
  • 1,554 Answers
Open it the keys are on a rubber membrane.
clean the board and the membrane
Posted on Feb 04, 2008
  • Karl Whisenand
    Karl Whisenand Feb 04, 2008
    it has to unsnap ,I usually start around the batteries.
    it will be hard.
TV comes on but non-responsive otherwise
I would purchase a replacement. The damage a surge can do is usually not economic to repair.
Sep 04, 2014 | Panasonic TH-58PZ800U 58 in. HD-Ready...
How to change picture size on Panasonic th-50px50u
You can press the [Aspect] or [Format] button on the TV remote.
Nov 03, 2013 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Panasonic plasma panasonic th-p42x10a green led on but tv takes long time for picture to appear
check for swolon capacitor in power supply or try to go in service mode and reset tv by pressing vol_ on tv and press recall button continious from remote tv will go to service mode then press vol_ on tv and ok from remote hold ok untill tv reset then unplug and turn on again.
Mar 06, 2012 | Panasonic TH Televison & Video
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic code
The code is 0051
on your sky remote press the TV button then
the select and Red button at the same time , hold until the led on the remote blnks twice
then press TV and enter code 0051 then press select and the remote will blink twice again to acknowledge the code
if you still have your Sky box manual all these details are in there also
im a sky engineer by the way , goodluck
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Pairing Sky+ Remote with Panasonic Viera remote
3. Press tv again
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
5,542 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
