Question about Sony CDX-454RF 10-Disc CD Changer
How to eject the disc tray when not connected to the car?
Is there a way of ejecting the disc tray when the unit is out of the car?
I tried to connect it to a 12v DC source - but the Eject button won't release the tray. The Reset button also doesn't do anything.
Thanks!
  • lib_id Feb 09, 2008
    Many thanks, but I couldn't find the hole you mentioned on the right-hand side of the changer.
    If you meant the 'Reset' hole, it's on the left side of the 'Eject' button, but doesn't release the tray...
    Can you be more specific regarding the location of that hole?
    Thanks!
    New Friend:
  • 3 Answers
Hi---my 10 disc CD changer from 2000 mitsubishi montero does not stay in. when I push the magazine down . it won't stay. it will come up again. but the radio and cassette working fine. any thing wrong?
Posted on Dec 08, 2009
    Master:
  • 619 Answers
HI , to enject cd is look a piece of strong tooth pick insert to a small hole at right corner of cd changer , push and and push tooth pick until the tray comes out.
Posted on Feb 02, 2008
  • Anonymous Feb 10, 2008
    Hi, near the push buton at the right side of cd tray front face.
6ya staff
SOURCE:
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
Jan 21, 2015 | 2004 Ford F150
CD deck
That means that there is a mechanical error concerning the tray gears
Oct 11, 2008 | JVC UX-S57 CD Shelf System
It won't eject and makes a noise when I press the eject button
Sounds like the disc is stuck.
Look for a pinhole around the CD-Tray area, and straighten out a paperclip, and shove it straight back into the hole.
This should release the tray lock and eject the disc enough that you can remove it.
Once you have the disc out, try the eject button and see if it returns to normal operation (you may need to unplug and plug back in the unit)
Feb 27, 2011 | Bose 3 2 1 GS Series II DVD Home...
Can not get the magazine to eject have a fuse but everytime i reset the fuse i get a little juice but then nothing, What fuse should be used on this unit and where is the manual eject/
you have to open the cd changer and you will notice that 2 or 3 disc move to the right side under the tray or on top
pusch them back into the cd magazine but don't force the unit and don't move the disc on the tray
now power it again and press eject
good luck
Nov 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
Unit will not eject CD will play fine but won't eject
Once it gets too hot in your car, a stereo or the cd in it can warp.If you press the eject button and the music keeps playing the unit has an electrical problem you can't fix. If you press eject and the disc sounds, or looks like it wants to come out, you might have a warped disc. As a last resort, pull out the stereo and leave it connected. Then try to eject it. If it ejects, then the stereo could be binding.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
Apr 12, 2010 | Clarion XMD3
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
DVD will not eject
To eject a disc.
  1. Use the eject option in the menu bar by selecting open from the drop down menu.
  2. Press the eject or F12 key on the keyboard.
  3. Open the drive face plate and insert the end of a paperclip into the small hole under the drive tray area. This will pop the tray open.
Hope this helps. Don't forget to vote or leave feedback, Thanks.
Feb 23, 2010 | Apple eMac G4 Desktop
Disk won't eject on my iMac
Ok, I assume you have hit the eject button on the keyboard. Try dragging the CD icon on the desktop to the trash can. If that doesn't work, Shut down the computer and start up while holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Another option is to open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder. Another option is to Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Lastly if your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button. One of these should work.
Sep 03, 2009 | Apple Mac mini G4 Desktop
Cd magazine will not eject,power is connected any soloution
Try holding eject as you turn the unit on? should clear any cd's in the transport then try ejecting. Good luck
Jul 03, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
USA SPEC MERC99
Unplug all the cables, leave it out for several hours then replug it in and eject. This happen to me, I called 1-800 Mercedes and that's what they told me and it worked.
Sep 27, 2006 | USA Spec MERC99 6-Disc CD Changer
Sony CDX-454RF 10-Disc CD Changer Logo
453 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
