Question about Denon D-F101 CD Shelf System
Denon df101 cd player problem
CD player fails to read CD, works on rare occasion then fails, tried many different CD's
  • 107 Answers
Can't read now? with any cd's? if that happens try to adjust the trimpot/variable resistor beside the optical lens(its still part of optical lens) I just dont know if it turns clockwise or counterclockwise, well turn it on the other side then turn again to the other side. little by little. then if it still not working, you need to change your optical lens though.
you can do this if you are a pro..
note:
stay away at the power supply, never touch any part.
hope I helped you..^^
Posted on Feb 02, 2008
Why did my Denon Carousel CD player stop working and can it be fixed?
I'm not sure if this will help, but when that happened to my CD player the solution was very simple. I removed the outter cover and took a Q-tip dampened with some alcohol and cleaned the little lens that reads the cd. It's a very common problem, and the fact that yours is 15 years old guarentees the lens is dirty. Some people trash their stero when It could've been good as new with just a Q-tip & little alcohol.
I hope it works!
Laura
Mar 05, 2015 | Denon Audio Players & Recorders
Denon 2910 CD player malfunctions
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
I have a Denon DCD820 from the late 80's. This week I wanted to reuse it after remodeling my house and putting it aside for one year. When inserting a cd, sometimes it starts spinning and the shows the...
Couldn't find much for that specific Denon model but there is lots of info on basic CD player trobleshooting. If this video isn't helpful, do a youtube search or google "cd player troubleshoot"
Jan 08, 2015 | Denon Audio Players & Recorders
Denon ucd70 cd player drawer stuck
The gears have jammed, or the timing gear is out of sync, broken loading belt, and in rare cases a cracked cogwheel. This will need to be assessed to see if a repair is viable.
Mar 25, 2012 | Denon Audio Players & Recorders
I have a denon s-3500 and it will not read the cd?
hi if you have tried cleaning the lens gently .. then ... on these models the laser OPU oftern fails . so you will need to change the laser ..when you say will not read the cd does it try to spin or just sits there doing nothing.. i can provide replacement laser and service manual if you require them...yammandan
Aug 19, 2010 | Denon DN-S3500
I am trying to connect a Kenwood CD Player to the Denon amp. I am using normal av cable and connecting the output from the CD player to the ''CD'' jack of the Denon amp (no 2). I am not able to get the...
I agree with this answer:try to connect the CD Player output to the working input on the Denon Amp( say tuner remove it temporarily).
try if it works, then you have a good CD player
if not check if there is volume available on CD player , turn it a little bit higher, using remote control
check if the CD is reading the disk
check also the connector you are using
check if there is a known working CD audio inside the player
if still having problems state the model of your CD player
hope this helps, thanks for using Fixya!
Aug 22, 2009 | Kenwood Audio Players & Recorders
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
READING CD'S
well maybe it needs to change the optical lens now. but try to adjust the variable resistor at the optical lens. I don't know if its turn to left or right.
Feb 07, 2008 | Denon DN-2600F CD Player
Cd player not playing some cds: denon cd player ucd-77
try cleaning your not working cd with soap and water, and dry it with paper towel. tnx
Jan 30, 2008 | Audio Players & Recorders
Cd player flopped @ a party
This is a normal problem with these players. Trust me I own two of them. There is an overheating problem with them. they usually oveerheat after about 3 hours. I usually just throw on a long mix and let the other player cool off. Check the unoffical Denon forums and you will see that this has been a problem for years.
Sep 09, 2007 | Denon Dns1000 Table Top CD Player CD...
Denon D-F101 CD Shelf System Logo
339 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
