Question about Philips HTS-6500/37 System
Hdmi Hi hope some one can please help me !! i just got a hdmi cable put it on and my home theater (hts6510) and philps tv.Now it wont play the tv chanels sound but plays fine on its own, if you put a dvd in and go to hdmi chanel 1it is fine, i have 2 hdmi ports on my tv and i have tryed both but still nothing, it was working fine with the scat lead but was really really wanting to use the hdmi to link both together... please can some one help ...many thanks :-)
  • 476 Answers
The HDMI lead only carries the video and audio from the HTS6510/05 to the TV.
The scart carries audio and video both ways.
Re-connect the scart lead and all will be ok.
N.B. When the HTS6510 is switched on, the TV will auto-switch to the scart input. You will then need to switch the TV to HDMI to get the benefit from the DVD upscaling.
Posted on Feb 13, 2008
SLOW UNFOCUSING AND BLURY PICTURES ON MY HISENSE TV AND LG HOME THEATER
Single speed between new tv and old player may be causing latency. Double check specs on the newest component and make sure they are upward compatible.
Dec 30, 2014 | LG Audio Players & Recorders
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Panasonic Home Theater System System
Hi my Philips HTS6510 Home Cinema is frozen, it just shows
Hi, mine is also blocked, completely frozen. it also shows AUX and won't react to anything. Have you already solved the problem? Whad dit you do?
thx for the effort to reply,
greetz
Dec 14, 2009 | Philips HTS6510/05 Theater System
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Unabl to play dvd
hi angedembe, guess your dvd lens is dirty or worn out.try using a dvd lens cleaning disk this might solve your problem n if it still of no use then u have to change your dvd lens.hope the 1st method solve your problem.have a nice time..
raj..
May 11, 2008 | RCA 420Watt 5-Disc DVD/CD Progressive Scan...
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Philips HTS6510- Content cannot be displayed (Non HDCP Compliant)
Hi Joey,
This is the my second HTS6510. I sent the first one back in August as it would not play the disc nor eject it and I'd only just got it. The replacement has worked well until recently when virtually the same problem you are experiencing happened to mine without "the contents cannot be displayed" bit. It corrected itself but did the same thing tonight and this time it sometimes displays the "content cannot be displayed" bit. I think it is the HDMI out connection that is at fault. Could be that it cannot cope with the sound, but I'm a long way from knowing how these things work. If you come back on site and know the answer please share it with me. I will be getting onto the seller in the morning as it's still under manufacturers warranty.
Cheers.
Oct 18, 2007 | Philips HTS-6500/37 System
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Philips HTS-6500/37 System Logo
271 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
