Question about Microwave Ovens
3 microwave ovens in 18 months - all won't heat up - what is causing the recurring problem?
First model (Nu-Tec) lasted well over 3 years then it popped (almost the same noise one gets when metal is put in by mistake) while heating food one day and never heated again. Everything seems to be normal apart from the main task it is supposed to perform - heating. Bought a new microwave - Defy (DM0289) - this lasted just over a year and then exactly the same thing happened. Bought another one - same model - this time it only took 2 months for it to happen again. I live in Namibia in the middle of nowhere and there is a real shortage of experts in this field. After reading up on your website how to fix this problem I am not going to risk my life as the nearest hospital is an hours drive away. I just want to know why this is happening so frequently and if there is anything I can do to prevent it from happening to the next new microwave oven.
Please help
Carla
  • africat Feb 03, 2008
    Dear Totalwreck, Do people actually run microwave ovens without anything inside? What for? I am not one of these people, there was something in the oven every time all three ovens died on me. I do have a warranty for the newest one but in this country it works as follows: you take the appliance into the shop and tell them about your problem. They say we will have to send it to the supplier to be checked and repaired if possible. Only if it cannot be repaired, will we replace it. In the meantime you do without and this could take months. In the past I tried to return a fridge that never worked from the start and this is what I was told. Customer service and satisfaction comes in the form of take it of leave it. The microwave oven is matched to the electricity needs, both voltage and cycles and I definitely won't be buying the same model again but I am not sure the same thing isn't going to happen again. We have a lot of power failures here, do you think this could be the source of the problem? Although no power failures occurred when the 3 ovens stopped working. Do you think power surges could be the cause? Is there anything that can be done to make sure the next microwave oven lives a little longer than its predecessors?
    Dear Totalwreck, I am all for trying new ways to do things but common sense has to prevail at some stage. I am now going to go out and buy a new and different brand of microwave, as well as a surge protector and see what happens. Hold thumbs. If this doesn't work, I will get in touch. Thank you for taking the time to help. Regards, Carla
    Scholar:
  • 43 Answers
Carla, Sorry to read of your troubles. Your unit that is only 2monts old should be under warranty, or did you receive any warranty?
What you describe as " the noise one gets when metal is put in by mistake". The noise is Arcing of Microwave Energy. Do not operate a Microwave Oven DRY (without something inside that will absorb the Microwave Energy. A Dry-Run Microwave Oven will feed-back upon itself and do damage.
If your unit is matched to the electric needs, both voltage and cycles, then I would not get another one of the same Model.
Posted on Feb 02, 2008
  • Totalwreck Feb 03, 2008
    Yes Carla, I repaired Microwave Ovens for 30years. I am now retired but still trying to give back through my knowledge. It would amaze you, the things that have been put in a Microwave. One University Student tried to dry some clothes in her small MW. The metal hooks arced and set the fabric on fire. Total loss.
    If your Microwave Oven : RUNS BUT DOES NOT HEAT. It can be broken down to failure of one of three components.
    1. HIGH VOLTAGE DIODE
    2. HIGH VOLTAGE CAPACITOR
    3. MAGNETRON
    Power Surges can cause failure of these components. Because they are in the High Voltage side a voltage surge would feed even HIGHER VOLTAGE from the High Voltage Transformer. A GOOD Surge Protector would help.
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Model NN-6603A unit won't heat
If the microwave oven is 7 years old or less, the cause is a bad magnetron, or the inverter board is malfunctioning, due to cost in parts and labour cheaper to replace.
Jun 29, 2012 | Panasonic Microwave Ovens
My whirpool microwave model wmh2175xvb1 Won't Heat
The problem is caused by the magnetron,"heart of the microwave oven" or the inverter board, if 7 years or less.
Apr 16, 2012 | Microwave Ovens
I have an Electrolux High Speed Oven E30SO75FPS that's 3 years old and the Magnetron has failed for the 3rd time. What can be causing this?
Is the internal cooling fan working?
Are the ducts and vents clear?
Problems with any of those can result in overheating, which destroys magnetrons.
I have seen high voltage rectifier diodes interact with magnetron in funny ways. I'd replace the diode, too.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Finally, baking potatoes and making popcorn really give the magnetron a workout.
You should put about 1/2 cup of water in the rear corner of the microwave when cooking those foods.
It helps "preload" the oven to prevent execessive microwave energy reflection back to the magnetron.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 12, 2011 | Microwave Ovens
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
UNIT 18 MONTHS OLDS. IT WILL RUN BUT NOT HEAT.
There are three things that will cause this, the magnetron " common problem " and the high voltage capacitor and diode, cost can run high depending on the nature of the repair.
Feb 14, 2011 | General Electric Microwave Oven
Will not heat the food.
I it is due to the defective magnetron in the oven. You need to replace the part.
May 26, 2009 | Emerson Black Microwave Oven
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Nu-tec NTV2131 51cm TV
Press the 'display' button for 5 seconds
Mar 31, 2008 | Hotpoint RVM1625 Microwave Oven
Microwave Ovens Logo
178 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
