Question about Xerox Phaser 6110 Laser Printer
Xerox Phaser 6110 - what does continuous red light mean ?
My Xerox Phaser has had status light turned to red for last few weeks - but the printer still seems to work OK - yesterday got a toner low message also - replaced the toner, but the red light is still on. The guide says I should contact a service representative - do you know what the problem is or who I should contact to this resolved ?
  • Anonymous Jan 24, 2009
    i have a red light and it doesn't print at all.
  • Anonymous Mar 17, 2014
    xerox phaser 6110
  • 37 Answers
Lemmor, without being rude it sounds like you know nothing about this machine at all.
The printer version of this machine has 5 lights in total. 4 of them refer to the toner carts (flashing means toner low, on solid means run out) the other light (the status light) can mean many things. The most common problem people overlook with red status light is that the waste toner bottle is full and needs replacing. It can mean lots of other things depending what colour it is and whether it is flashing or not. These can all be found in the user manual, or if the status monitor has been installed (usb connection) it should show on the PC screen. With a network install, you can browse to the machine using it's IP address to see the error message.
Posted on Jun 30, 2008
I had the same problem. My solution was: Pull out your toners and reinstall them, make sure they are pushed in all the way.
Posted on Oct 17, 2010
  • 749 Answers
The red light is a warning that a part inside the printer is wearing off or nearly to be replaced with a new one... The most common of all is called the drum, it is replaced to achieve a clear print-outs, that can be the heater, or some rollers. It is better to have the printer checked thru a printer repair shop to determine that part....
Hoping this helps... Fixya...
Posted on Feb 02, 2008
WiPer,
Please simply address the issue. There is no need NOR is it helpful in anyway to state:
"Lemmor, without being rude it sounds like you know nothing about this machine at all."
How does this comment resolve the issue? If you are going to offer help, JUST HELP!
Posted on Aug 04, 2008
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
How to install xerox phaser 6110? I do not have any driver
This page has drivers for your Xerox Phaser 6110:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=6110&Xlang=en_US&Xcntry=USA&prodName=Phaser%206110
Apr 28, 2010 | Xerox Phaser 6110 Laser Printer
Red in xerox 6110
check the waste toner (it's on the left side of drum unit when you open the front cover) cartridge or paper jam if blinking!
Dec 04, 2009 | Xerox Phaser 6110 Laser Printer
A red light all the time on xerox phaser 6110.
I think I might know what this is. Mine did the same and I removed the waste toner cartridge (grey L shapped unit to the right of the colour cartridges under the front panel) I noticed it was quite full but a rocked it from side to side to settle the contents (be carefull as they can come out) and when refitted the light stayed off when powered up. I'm not sure if this waste cartridge needs to be replaced or you can simply tip it out into a bin, but I'll try that tomorrow when I can empty out side.
Jan 24, 2009 | Xerox Phaser 6110 Laser Printer
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
Phaser 6110 - red light on, not printing
Just had user with same problem. Printer status = paper jam but no paper in feed path therefore suspect paper pick up problem. Asked user to take out paper tray and turn paper in tray over. This solved problem.
So possible fix = turn paper over or try different paper.
If printer is old try cleaning pickup roller. My users printer had only done 227 pages.
Sep 11, 2008 | Canon PIXMA® MP530 All-In-One Printer
Xerox Phaser  6110 Laser Printer Logo
6,076 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
