Question about Medion MD 7317 17" Flat Panel LCD Monitor
Medion flat screen monitor MD32119
WHAT IS THE WHITE PLUG CONNECTION FOR?
  • 4234 Answers
SOURCE: how to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Posted on Apr 09, 2008
  • 263 Answers
SOURCE: flat monitor..it only appear white in the screen...how to repair?
I think the monitor has had it unfortunately it would cost too much money to repair it , you would be better off buying a new one as they are so cheap nowadays.John
Posted on Jul 30, 2009
SOURCE: medion md 7317 flat screen monitor
* 470uF 25v capacitors + 1 * 220uF 25v on inverter board, all with bulging tops. Replace them all (note 105 degC variety) and monitor works OK!
Posted on Sep 02, 2009
SOURCE: medion 22 in flat panel monitor does not switch on
There could be an internal fuse problem or there are leaking capacitors on the mainboard.
Posted on Nov 05, 2009
ctau
  • 372 Answers
SOURCE: How do I use the
Have you plugged in the audio cable from your monitor to your computer?
Posted on Aug 11, 2010
AUDIO LEADS
There should be one audio cable, Green.
goes into one of the green plugs behind the computer.
Oct 31, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
My moitor has a yellow screen instead of white
check the vga cable which may have loose connection.
Oct 10, 2012 | Medion Computers & Internet
Medion monitor won't come on
inverter has gone .cheaper to buy another monitor
Apr 26, 2010 | Medion MD 7317 17" Flat Panel LCD Monitor
MONITOR MEDION MD7317 NOT WORKING
i have some 19 inch medion monitors that have the same problem .. they make a lot of noise and the screen might be jittery/fuzzy ... i found the following:
several capacitors in the power supply (inside the monitor) had their tops buldging .. that shows that internal pressure was high in the caps, usually caused by them being hot and thats caused by high internal leakage .. the caps may eventually blow out the tops (explosion vents) .. the caps are designed to do that instead of becoming a bomb ..
all the bad electrolytic capacitors i have seen so far on these monitors, motherboards and other electronics have been chinese made .. they made millions of bad caps over several years ..
almost all the bad caps had buldged tops but not always .. once in a while i see one thats open but not bulbged .. probably venting elsware ..
i changed the obviously bad caps and the monitors returned to like new performance ..
i dont know about the 17 inch but the 19 inch medion flat pro display is not too hard to take apart .. about 30 screws or so ... speakers have to be unscrewed and you have to be careful not to stress cables that go to the push buttons .. of course you have to know how to solder without bridging paths
Feb 02, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion 15" lcd pc screen
Do you have any speakers or electronic devices near your monitor... they can be the reason. Or you might have to take it to the hardware engineer.
Aug 20, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion tv wont work
look at the components board the fuse holder is in and you will find a hot spot burn mark ...thats the component thats blown and shorted the internal fuse
Mar 20, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion MD 7317 17" Flat Panel LCD Monitor Logo
299 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
