Used ramsa wrs4412 mixing console
I need help with getting operators instructions and making sure all cables are connected correctly, diagram would really help and step by step instructions, can u help?
  • anne06 Jun 29, 2008
    Can anyone help? I have lost the user manual and cannot find one to download for free. I just want know where to put the speaker connectors. There are 2 Left and 2 Right conectors (one Red, One White) and each speaker has one grey and one black wire.
    Problem Solver:
  • 22 Answers
Maybe...wat system u got?..u know(make/model/year)
Posted on Feb 05, 2008
Can I run a power amp for monitor speakers into the RAMSA 52 SX1 mixing console
U need to convert the speaker outputs to a more manageable line output(s) to feed the mixing console.
Jan 02, 2016 | AMP Music
Why am I notI getting a picture?
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If not, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If the above troubleshooting doesn't fix the problem, click here.
Mar 29, 2013 | Nintendo Super NES Console
Picture for Wii game is in black and white only.
What type of cables are you using? My presumption is that you're using Component Video Cables - Red, Green, Blue for video, Red & White for audio.
If one of the 3 video cables is mixed up or poorly connected, you could see a Black & White image on the screen. I suggest double checking your cables for tightness and correct color attachment. Also be sure the red video is not mixed with the red audio cable. The red audio cable is marginally thinner and probably physically attached to the white audio cable.
May 05, 2011 | Nintendo Wii Console
Snes console scart wires blank screen
Troubleshooting - Video
Quick Tip! If you already have your system connected using AV cables and you are getting a blank screen, it is likely all you need to find is your input select, Check out our Input Select Locator
Blank Screen
Scrambled Graphics/Other
Blank Screen
Other Screen Problems
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
If the above troubleshooting doesn't fix the problem, see below.
What to do if Troubleshooting Doesn't Help
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product. If you simply need to order parts or accessories, you may want to check out our Online Store. Nintendo's Online Store still carries many parts and accessories for our older products.
Mar 30, 2011 | Nintendo Super NES Console
My playstation wont transmit a picture to my television
Make sure everything is connected correctly. Then, turn on the PS3 from putting your finger on the "power button" but HOLD IT DOWN. After a few seconds it will beep at you a few times. Check the TV. If the video OUT settings got messed up somehow, it should now display picture on whatever cables you are using "HDMI" or "Composite" . Hope this helps!
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
Wii Console: error code 51420...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
May 17, 2010 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Error code 51420-- wii is hooked via usb to modem and unable to connect
This is directly from the Nintendo Tech Support Site
  1. If your connection worked previously, check to see if thereis a Wii System Update that you have not aquired. To get the latest WiiSystem Update:
  3. Check to make sure you are not running the Wii LAN Adapterfrom a USB hub (a device that connects multiple USB products through asingle device), as this will likely not work. Connect the USB Connectordirectly to the modem or router.
  6. Ifpossible, try another Wii LAN Adapter. If you are unable to try anotherWii LAN Adapter, or are still receiving this error code, please call1-800-255-3700 for assistance.
If you need step by step instructions on how to set up the Wii LAN, click this link
Installing the Wii LAN Adapter
Dec 08, 2009 | Nintendo Wii Console
Xbox360 elite
do u have a router and if so u need to make sure these ports are open
If you have not already forwarded ports for your xbox through your router then that may be your problem.
The following ports must be available to your Xbox 360 console for Xbox LIVE to operate correctly:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
Jun 14, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
White lines, images on screen turn funny colors, audio humming
Hi :)
I had small white dots appear on the dashboard screen, like static... I am using an HDMI connection.
Make sure that your cables are connected correctly...
Try going to the display settings and selecting the automatic setup for HDMI, that worked for me, it looks pefect now..
my problem is that discs are not loading(but that's a different issue)..
It might work the same way if you're not using HDMI.. just select your connection again, or change connection settings and back again. But make sure that you select the correct settings if you want it to display correctly.
I hope that helps, good luck.
Jun 11, 2008 | Sony Playstation 3 (PS3) Console
357 people viewed this question
 Grubhead
Grubhead
