Question about Canon ZR85 Mini DV Digital Camcorder
Canon ZR85 my canon zr85 camcorder has worked fine for several years. one day i went to use it and it would not turn on. i plugged it into the charger and it comes on, but there is no display and the tape won't eject, it just makes a whiring sound. then it starts beeping all of the sudden and shuts itself down. also, the tape will not eject???
  • 3 Answers
You may need to reseat the connectors inside the camcorder.Close the LCD. Hold the LCD side in the palm of your non-dominant hand. Give the opposite side a good cupped-hand whack (do NOT whack the LCD! The opposite side!). Be careful.
Posted on Feb 02, 2009
  • 73 Answers
THE COMPARTMENT IS OF TRACK THIS WILL NEED REPAIR SORRY THIS IS ALOT OF MONEY
Posted on Mar 02, 2008
My canon zr85 mini dv camcorder the screen is black when on record even if the side screen is close the eye unit is also black.
It is known problem of ccd imager chip failure in Canon ZR85 camera and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you to replace ccd imager chip because solder work is involve.
Thanks.
Jul 21, 2010 | Canon ZR85 Mini DV Digital Camcorder
Zr85 camcorder will not turn no lights no power
Ok, let's try the "easy fixes" first. When this problem happens, it can be a oxidized power switch contact, or oxidized battery contacts on the camera. Clean the battery contacts and the contacts on the camcorder with an eraser gently (they are gold plated). See if the camcorder works now. The next step is only if you're not planning on taking the camcorder apart. There are times when you can give the camcorder a slightly hard "whack" with the palm of your hand, somewhere near the power switch, while the power switch is on, and if the camera works, then you know it's most likely a dirty or oxidized contact inside. See if you can get it working with these methods. If you can't, you will have to disassemble the camcorder or have it serviced. Get an estimate if you get it serviced, since it can be expensive, and you might just opt for a replacement.
Apr 23, 2010 | Canon ZR85 Mini DV Digital Camcorder
Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
Dec 03, 2009 | Canon ZR800 Mini DV Digital Camcorder
I can playback the tapes but now I can't see anything on the screen when I want to record. The screen is just black. Is something not set correctly?
If your camcorder is Canon ZR85 then it has bad ccd imager problem and that part will be replaced to see live view in camera mode for recording.
Canon offers Free of Cost repair for ZR85 model.
Click Canon CCD Imager Support for details.
Apr 07, 2009 | Canon ZR85 Mini DV Digital Camcorder
Image distorted in both modes canon zr85 camcorder
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced to back in business.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Dec 25, 2008 | Canon ZR85 Mini DV Digital Camcorder
Me screen is black but everything else works
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Good luck.
Canon zr85
You should probably take it to the camera shop and see whats going on with the power supply.
Jun 14, 2008 | Canon ZR85 Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
Not able to record the image
I had a similar thing happen to me...the video would not come one when I turned it on, but the audio would work, and it would play back tape fine. I happened upon the following solution (though I don't know how long it will last). I charged the camera, and then noticed it worked fine when the charger was plugged in. As soon as I unplugged it, the video would go black. So...I plugged it in, turned it to record, and unplugged it, and it worked! Almost like something got reset. I have no idea how long this will last, or if it means the battery is going...but, give it a try!
May 06, 2007 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
250 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
