Question about Acer AL1715 17" LCD Monitor
Acer AL1715 - insufficient brightness
After a mains power outage my Acer AL1715 came up with a very low brightness screen. Confirmed as monitor fault on second PC. Brightness set at 100% in menu, but only highlights visible on screen. Pressed auto config which momentarily brings it up to full brightness, then it drops back to the low brightness screen again. Tried reset from the menu which also momentarily brings it up to full brightness, then it drops back to the low brightness screen yet again. It knows there's something wrong as it tries an auto-config ever time it powers up.
Is there an internal hardware reset button?
  • 1 more comment
  • bobbybear Feb 04, 2008
    Many thanks for the reply. The annoying thing is, (as an experienced electronics engineer), now I've had it to bits I'm sure there's no hardware fault, (& no internal reset, either!) - I guess the mains spike has corrupted the firmware which I'm guessing is in flash memory rather than EPROM, so to have to throw a 17" LCD monitor out just 'cos the firmware has been corrupted is annoying to say the least...From looking around, these monitors seem to be prone to this sort of problem.
  • bobbybear Feb 16, 2008
    I contacted Acer and it turned out that it was just inside its three-year guarantee period, so they organised it to be picked up on a Monday and it was back with me on Thursday - fixed! Brilliant service!
  • olgagabe Mar 15, 2008
    Couldn't view anything. Waited a while and the picture came up. Is this monitor on its way out? Is there anything I can do?
No there isn't any. there is probably a part that is damaged due to the surge u should get a new one or send it back to the company
Posted on Feb 02, 2008
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL175 TFT monitor is coming on but its very dim
The screen itself is starting to go bad which is why your having to turn up the brightness to 100% just to see something. Replacing the screen would cost more then the whole lcd monitor itself so its best to get a new one.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
My monitor will go on but it will not stay on
Either sleep timer is on or the refresh rate is set higher then the screen to handle or scheme is not set for laptop.
you can right click on main screen to access display and advanced options.
Oct 23, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1715 no lights
We are seeing this same "issue" with this model regularly. If there is no screen and No led/lights, then the power supply has gone out.
It appears on that model there is an external power supply.
Google the model number of the Monitor for replacement parts.
Plug something into the same outlet and verify the outlet is good.
Oct 20, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1715 power issues
I have an ACER AL 1706 monitor that would not power up completely. After pushing the power button, only the yellow light would stay on indication a power up fault. After careful inspection of the power boards caps, there was visible swelling of the 47mF and 22mF radial caps on the top part of the caps where the tiny cannisters 4 edges are folded down flat. I replaced these caps( 6 on my board) because there is reaaly no way to actually test them and bought new ones from Radio Shack. Now my Acer monitor came back to life with no other problems. I recommened using replacement caps with same microfarad values, but if the voltage rating is not exact, it is o.k. to get the next higher voltage rated caps available and should work fine.
May 01, 2009 | Acer AL1715 17" LCD Monitor
Monitor resolution problem
set your dispaly resoluiton to 1024*768
Mar 24, 2009 | Acer AL1715 17" LCD Monitor
AL1715 Acer flashes twice when starting up but does not go on
blown capacitors most likely cause, replacement of the blow caps on the main power board is advised
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1715 Monitor - screen distortion, discoloration, several times each day
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic lip interfered with the plug and so the plug does not seat properly. This causes all sorts of intermittent problems. The version of the AL1715 with the problem with had the UPC code of 0 99802 19889 3. I fixed several of these monitors by shaving off the excess plastic with a Dremel Mototool. A hand file would probably work as well. You have to remove the plastic back to get the clearance to do the job.
e82875f5-b8a2-4548-9fdb-e60e2a37e9f1.jpg 14e1c79c-dd10-4643-b23c-053cfb0678e4.jpg fcd3ba29-2571-453c-838f-32c7fa61078d.jpg 038eb9e5-53a2-4fa0-88b9-56eb63be9378.jpg 19ef87e5-fc9a-423a-af2e-b0d949b0e884.jpg 092e022f-c3ac-4aa4-86ff-99eaa0075f07.jpg fe6adb60-288d-425f-9d35-156c724a2285.jpg
Oct 30, 2008 | Acer AL1715 17" LCD Monitor
Had a power outage, acer monitor will not power up
Normally there is a fuse that can be replaced inside on the power supply board. The are usually "slow blow" fuses and need to be replaced by an equivalent fuse. Many monitors have a soft switch which is controlled by the main board that tells the relays to supply power from the power supply. The CMOS devices on these boards are very suceptible to static so ground your hand to the chassis before touching any boards. If the backlight is out but there is a faint image on the screen when you look at it closely then the inverter board or CFT tubes are suspect. BTW: watch the Power supply and inverter boards as the caps stay charged and could result in electrical shock. Good luck. Hope this helps.
Jan 03, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor Problem:
You may be encountering a hardware fault that numerous people appear to be having (myself included).
Get a bright torch and point it at the screen once it's 'gone blank'. Look for any text / images that you'd expect to be displayed.
You will normally see a faint display which shows that the problem is just with the backlights. Unfortunately the inverters for these are built into the power supply (Delta Electronics, model no. ADP-40AF) so you will more than likely need to replace this. It's probably easier, simpler and cheaper to buy a replacement (non-Acer) monitor!
Dec 06, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 17" LCD Monitor Logo
572 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
