Bios won't boot
After starting the computer, the fan whirrs, a few short clicks but no rat-a-tat-tat of the hard drive and the boot up stops right there. I figure it's the BIOS, but not certain. Light is on on the keyboard and the monitor (both green). No beeps from the computer to go by. I swapped my RAM and reseating them- still no luck. Can you help? It's a Compaq Presario
Iformated mi hard drive
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart If its an external hard drive or a usb pen drive click start right click on my computer select open you should see your pen drive right click then select format another way is to click start control panel administrive tools computer management disk management right click on your drive select format
Apr 02, 2013 | Toshiba Computers & Internet
Can't format my hard drive
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart If its an external hard drive or a usb pen drive click start right click on my computer select open you should see your pen drive right click then select format another way is to click start control panel administrive tools computer management disk management right click on your drive select format Hope this helps.
Jan 18, 2013 | Seagate Maxtor 80GB DiamondMax Plus21 SATA...
Can't format my hard disk
Jan 18, 2013 | Maxtor Computers & Internet
Format a hard drive
if its an external hard drive or a usb pen drive
hope this helps
Sep 21, 2012 | Dell Latitude E5500 Laptop
How do i format2tb harddrive
If its your primary hard drive with an operating system
you have to format a hard drive with a third party disk
If its an external hard or a data drive
click start right click on my computer select open you should see your usb drive
another way is to click start control panel administrative tools computer management disk management right click on your drive select format
hope this helps
Sep 17, 2012 | Generic 2.5"/3.5" eSATA SATA HDD Dock...
How to sol hard disk formate than use this problem
if you are referring on how to format a hard drive
hope this helps
Sep 01, 2012 | Computers & Internet
FORMAT NEW HD
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jul 03, 2012 | Computers & Internet
Format the hard disk
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup usually the F2 or the Delete key
Press and hold that key during the boot up process to enter BIOS the navigate to advanced bios features using the arrows keys press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
if its a usb drive
hope this helps
Jun 15, 2012 | Samsung Computers & Internet
System is not booting after saving bios with f10. it is also shutting down after certain time. Not booting until bios jumpers opened.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Apr 14, 2011 | MSI K9MM-V Motherboard
Oxcoooooof
pauljohnchef.
If you want the computer to boot from the CD, you need to tell the computer to boot from the CD. At start up the computer runs through each device one at a time and tries to boot from it and it will boot from the first device that has a boot log. Right now your computer is set to boot from the hard drive before the CD drive.
Always back up your computer before going into the systems bios menu.
After a backup, upon starting the computer, press F12 when the bios selection appears shortly before the operating systems starts. Once in your bios menu, go to the boot order and tell your computer to first boot from the CD then your hard drive; then your disk drive if you have one.
After you are done, you can go back into the bios menu and change it back to booting from the hard drive first.
-Chris
Feb 28, 2010 | Toshiba Satellite P205-S6287 Notebook PC
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
