Hard disk problem
My hard disk is crashed, it is under warranty, in that i stored some cofidential data which important to me. how can i recover the data?
please reply me.
  • 749 Answers
You'll need a lot of cash to do that... There are companies that offers data restoration... If you are that well-to-do person then go ahead... Right now, we just give you an advise.... It's your choice...
Browse the internet for an info....
Good luck...
Posted on Feb 02, 2008
How do I recover data from my failing hp pavilion 7935?
remove hard disk from pc and check your hard disk on other PC and take your all data
May 19, 2013 | HP Hewlett Packard Pavilion Slimline...
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
How to recover data from my toshiba 320 hard disk?
Data lost due to unintentional formatting of the drive or when someone knowingly delete some data later on realizing that the data was important, In situations like this one should use a data recovery tool. To know more about data recovery process visit http://www.recoverlostfile.net
Dec 23, 2012 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
I have a Verbatim 500Gb (model #47566) hard drive. After defrag and clean up, when plugging in, I get a message that the disk in drive K is not formatted and would I like to format it now? I know that if I...
People often feel panic when I see this. If I format the drive, will I lose all my data? If not, how could I get access to my files?
My take is that you may have to format the drive (use quick format) and then use recovery software to recover your files.
Here's some information about file recovery, think you need to take a look, very useful
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 26, 2011 | Verbatim Portable, 500GB, USB, 5400rpm...
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
How can we repair a USB which is crashed like a hard disk.
Dear i have send some information of solve your problem. I hope you have satisfied my suspicion if you can solve your problem you can read this information
Thanks.
Pen drive is the best way for people who are looking for larger space to store their important data and want a compact, easy-to-operate storage drive. These pen drives are mainly trendy among system and network administrators. They can load a large amount of information about configuration and software that can be used for the system maintenance, recovery and troubleshooting. But what if there is a problem with your pen drive having important documents have been crashed? Ddipr.com releases new USB repair software to ensure user to get back files and folders stored in USB pen drive.
Pen drive data recovery software securely restores lost digital images, office documents, database files, audio, video files etc from your damaged and logically crashed USB pen drive.
Ddipr provides advanced and professional USB repair application to recover missing or erased files and folders lost due to accidental deletion, virus attack, software malfunction or power failure etc from corrupted or formatted pen drive. Kingston pen drive files undelete utility easily restore data from various USB drive (flash drive, memory stick, jump drive, thumb drive, key drive) and many more USB drives. Thumb drive data restoration program provides reliable and secure method to recover all digital files format including midi, ppt, doc, pdf, mov, xls, jpg, gif, mp3, wav, exe, bmp etc. Software support pen drive in all capacities including 512MB, 1GB, 4GB, 8GB, 16GB, 32GB and even higher capacity drives. USB drive data backup utility support all leading brands like Kingmax, Samsung, Sony, Toshiba, Jet flash, Apacer, Lexar and many more. Software easily installs on all windows operating system such as Vista, 98, 2000, 2003, XP, ME, NT. The software development team of ddipr.com combines a variety of advance features in this particular software. Some of the important features are:
- Pen drive data salvage program recovers data even if Drive Not Formatted message is displayed on your computer.
- Software provides GUI interface which makes it easy to use and operate.
- Application supports all versions of windows like Vista, 98, 2000, 2003, XP, ME, NT.
- Software provides easy data recovery from logically crashed or inaccessible pen drive.
I am a company representative and fully satisfied with this application to restore deleted data from formatted or corrupted USB pe
Feb 16, 2010 | Kingston Technologies 512MB DataTraveler I...
How to extact the data off the Seagate Barracuda 7200.10 320GB HD
if its your motherboard that crashed then ther is no problem with your hard disk. connect your hard disk to any other computer and you can access all the files in it.
if it is your harddsik that crashed then try recovery utilities like western digital data storege manger or any other disk recovery tool available for free. if still it fails then you can recover your data if you hand over your hard disk to the nearest service centre. but recover from a hard disk only if its very valuable. thay will charge you per MB of data recovered
Jul 04, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Hard drive crashed
Yes any data recovery place will be able to astract whatever was written on that disk as long as it has not taking a serious fall you can get your data recovered under $15 a GIG so yes take it in if it is that important to you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Crashed hard disk
firstly you are delete the partion and then formate the harddisk of quick NTFS mathode .
and install the softwere of essy recover and choose the option of raw data recover .
shiv mishra
9654535008
Apr 08, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Hard disk crashed
I would use recover my files and pay the registration fee. They have an excellent product and it gets the job done 80% of the time.
When you say crash what do you mean? It's not spinning? corrupted data?
Jun 15, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
