Question about D-Link DI-704P Router
Internet sharing interruption within my network. is it because of my router? Because when i tried to standalone with the server, the internet is ok.
  • 3 Answers
Could be an IP conflict
Posted on Feb 02, 2008
How to use comupter as sever
Proxy server
Use a Computer as a Proxy Server
Small networks can still take advantage of a proxy server.
The Microsoft Windows operating system allows you to turn your computer into a proxy server.
A proxy server is a central computer on the network connected to the Internet.
Other computers on the network use the machine to connect to the Internet.
The Internet Connection Sharing (ICS) configurations on the machine allow you to turn your computer into a proxy server.
Click the Windows "Start" button and select "Control Panel."
Double-click "Network and Internet Connections."
Double-click "Network Connections" to view a list of network card settings.
Right-click your network card icon and select "Properties."
For most users, this icon is labeled "Local Network."
Click the "Advanced" tab.
Check the box named "Allow other network users to connect through this computer's Internet connection" in the section labeled "Internet Connection Sharing."
A warning message pops up telling you that your IP is reset for the proxy computer.
Click "OK."
Reboot your computer for the settings to take effect.
You also need to reboot each client machine on the network to ensure they see the proxy server.
Turn a Computer Into a Server
When you have more than several computers and users who want to share files and resources, whether in your home or in a small office, you can convert a computer into a server.
Building a server out of a computer will allow users to access files whichever computer they use to access them.
An example of the resources that can be shared is a printer and shared folders such as photos and documents. Here's how to convert a computer into a server.
Prepare your computer.
Clean up the computer with unnecessary files to save on space.
If your computer is really old, install the latest operating software so that it is compatible with the rest of the computers that will share its resources.
For this example, we are installing Windows XP.
Check the hard drive space or capacity if you have enough.
You can do away with 256MB sized old computer, but you may want to think about adding more disk space for future needs.
You can easily buy extra internal or external hard drives to bump up your disk space to a capacity that you would desire.
Try purchasing a 10GB extra disk drive then insert it in computer or connect via a serial port or USB hub it if it is external drive.
To install the hard drive driver on XP, let the hardware wizard run you through the options.
You can install the driver with the installation CD software that your hard drive came with.
Follow the options during installation. ,
Check your computer if the network card (ethernet card) is functioning properly. if it does not, you would need to install a NIC or Network Interface Card.
Some old computers have 10 megabit cards, but if you want to have high network performance and better connectivity through your LAN (Local Area Network) then you would need to upgrade your NIC by installing a 100 megabit or 10 gigabit NIC.
Install your network card driver using the installation CD that came with it then follow the installation wizard.
Get a network router. Connect this router to your high speed connection.
The most common ones to use are Netgear, Linksys or DLink routers.
Choose a wireless router so that if you have wireless users they can connect easily (plus this will save you on trying to connect cables to the router all over the place).
Set up your network connections.
Click on "Start," "Control Panel and "Network and Internet Connections."
Pick a task from the options listed or pick a control panel icon, in this case "Network Connections."
If you are set up to pick up the IP Address of your computer automatically, one you have installed your NIC in Step 4 and rebooted, it will pick up the connections automatically whether plugs in using a LAN or network cable or using wireless card.
Rename your computer. Name it so that it can easily be identifiable in your network.
You can either name it simply "SERVER" to be easily recognized, but it is all up to you how you want to name your server.
To name your server if you are using Windows XP, you can right-click on "My Computer" then click on "Properties."
Go to "Computer Name" tab then click on "Change."
Other Windows operating systems or versions would have this feature located somewhere else. Read the owner's manual that your computer came with it.
Create a shared folder by going to "My Computer" and "C:\Documents and Settings\All Users\Documents."
Create a new folder by right-clicking on the screen, then click on "New Folder."
Name the new folder "Shared Files" or anything that can easily be identifiable.
Take note that on Windows XP, any folder that you create and then dragged into the "Shared Documents" folder will be automatically shared by everyone.
You can restrict certain folders by dragging the folder out of the "Shared Documents" folder, then right-clicking on the file folder, clicking on "Properties," then the "Sharing" tab and finally "Make this Folder Private."
Create a shared resource by adding a printer or fax to use. Go to "Start."
Click on "Printers and Faxes" and "Add a Printer," then let the installation wizard that came with the printer or fax guide you.
Name your printer or fax (for example, "Shared Printer").
Then once the printer is installed, set it up so that you can share it by right-clicking on the "Shared Printer," then on "Properties," "Sharing" tab and finally on "Share this printer."
Connect any computer to your server.
Go to each computer and ensure they are connected on the same router.
Then go to "Start" and "Run," type in "EXPLORER," then on the menu click on "Tools" and "Map Network Drive."
A window will pop open where you will assign a "Drive" letter and a "Folder."
Choose any driver letter, for example "G" to denote "Group" drive or "S" to denote "Shared Drive," then type in the IP address of the server.
To do this, go to the server, then go to "Start" and "Run," type in "CMD" then type in "IPCONFIG." This will display your server's IP address.
Type the IP address on the "Folder" field on the computer.
You can also try if the computer will automatically find it by choosing the drive letter then clicking on the "Browse" button on the "Folder" field.
Start using the shared resources by going to the drive letter that has been assigned on your computer.
Sep 24, 2013 | Computers & Internet
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
MY INTERNET WILL NOT STAY ON FOR MY LAPTOP BUT MY MAIN COMPUTER IS GOOD
The computer that aready has the internet connection shares the signals with new computer by router devices. Connect all the structures, cables, power curciuts, etc. The computer that has the original network is called administrator server. Access the server computer add devices to network structures to ascertain foreign devices existenc and confirm request to integrate to old structure.
Feb 06, 2011 | Belkin (F5D7230-4) Router (587009)
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Internet Sharings
hi
first of all can u plz tell me how do u connect to internet like u use a connectiode or something if yes its very easy u just need to right click on the connectiode & just go to properties click on the advance tab & under the internet connections sharing put the check mark on allow other network user to connect to internet through this computer internet connection thats it. u will be able to access the internet on all the pc on ur network. incase if u still have any problem just let me know & also provide the details on ur network like how u connect, any router hub or switch is been use for connecting pcs etc
Oct 02, 2008 | Computers & Internet
Problem with network
Make sure the physical connections are correct. Modem connected to the Internet Port of the router and your PC to port number 1 on the Linksys router as well. Try to reset the router. Hold the reset button at the back of the router for about 20 seconds. After that, unplug the power to the router and to the cable modem. Wait for 30 seconds. Plug the modem first, wait for the lights to stop blinking then plug in the router. Check if the internet works fine again.
Sep 06, 2008 | Linksys Computers & Internet
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
What is the main difference between WinGate and the Prestige 310 ?
# WinGate is a software only solution that needs to be installed in a dedicated Windows 95 PC based server. The total cost and complexity are many times over ATI?s product. The Prestige 310 Internet Access Sharing Router is a plug-n-play internet appliance. # WinGate requires all TCP/IP applications such as Netscape Navigator to be reconfigured to have the dedicated server as a proxy. The Prestige 310 Internet Access Sharing Router does not require users to reconfigure any software at all. # The Prestige 310 Internet Access Sharing Router uses Network Address Translation (NAT) scheme, which supports all TCP/UDP ports. WinGate only supports limited number of ports, such as http(80), ftp(21), telnet(23), and pop3(110). # WinGate works as a proxy, while the Prestige 310 Internet Access Sharing Router works as a gateway. The gateway approach is more efficient than the proxy during the processing of TCP/IP commands. As a result, the Prestige 310 Internet Access Sharing Router achieves 10% to 20% higher performance than that of software solutions such as WinGate. # The Prestige 310 Internet Access Sharing Router uses Solid State Disk technology. There are no moving parts in the product. It is much more reliable than any hard disk based system, such as the one for WinGate.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
D-Link DI-704P Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
