On the left side of my projection tv, the convergence colors are moving. i cant fixthis with the remote. the crosses are kind of bent. can i fix this
  • 8,617 Answers
You will need a service manual. A component in your convergence circuit is at fault. Let me know your make and model and I will post a link where you can get the manual fast at the lowest price.
Posted on Feb 02, 2008
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
I cant line the red and green crosses up left and right but i can move them up and down. I have two pics in diferent colors
The tv have a convergence problems,it is dead.Tv have colors lines like R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
May 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 06, 2010 | Mitsubishi WS-65869 65" Rear Projection...
There is a line right in the middle of the tv going vertically.. the left side is fine but the right side is like 3d tv.. why is that.. Model # WD-62628--- S# 117086... Mitsubishi
  • Screen looks 3D
May 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a ultrascan hd the convergance is off i dont have an owners manuel it tells me to use a curser what do i do to get the red blue right ?
The cursor probably is just a cross in the center of your TV screen whichever color your setting will be a color cross that you want to move by using the up, down, left, right, buttons on your remote. You want to move your color cross over the top of the center cross until it looks like one cross. Generalized setting instructions can be found here.http://www.ehow.com/how_2034880_perform-convergence--tv.html
If this helps let me know with a vote.
Mar 04, 2010 | Televison & Video
Red and green lines, kind of 3D looking???
  • Screen looks 3D
Feb 28, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Colors do not line up on my tv ( left side of sreen looks like 3D) digital array "+" are only white on right side.
  • Screen looks 3D
Jan 11, 2010 | Hitachi 50FX20B 50" Rear Projection...
Shadows on left side of screen,right side has no shadows
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Nov 28, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Convergence problem with Toshiba TV 42H83
I am still working on it! Need a technician in Alacante Spain!
Jul 25, 2008 | Televison & Video
CONVERGENCE
http://www.digitalhome.ca/forum/showthread.php?t=21847
convergence ic bad
Dec 03, 2007 | RCA P46812BL 46" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
