Question about Epson DFX-9000 Matrix Printer
Noisey vibration hi i try to park either paper in front or back tractors .when the feed is in reveresei get this loud chattering noise and see the paper guide above the print head chatter (vibrate)and make a loud noise live gear cruncing although it cant be a gear as it is ok when winding paper forweard and ok when printing.only happens in reverse
  • Anonymous Feb 06, 2009
    I had the same problem but it is not printing. So, I had to take off the paper on one side, then it printed.
  • nilesh raj May 11, 2010
    Hi
    check the paper guide , is it still straight or has curled
    Novelist:
  • 103 Answers
Dear Rab,
Hope this solves your problem. I understand that you are having problem only on the reversei side tractor feed problem. We have encountered same problem even in different models and brands. Please check the Lever Paper Fed Selector is engaged well, so that the gears give less space clearance to each other. Please check the tractor tray is locked tightly both ends. Please check if the grease on the paper tray and contacting gears are not dried up. Please check also the paper path if there are remains or clogged parts of paper perforation holes. Finally check the flatten (stainless still or hard plastic) paper against the roller if not to tight. You can check manually by turning the paper roller knobs back and forth. But take NOTE: Turn Off the power in doing so, it may destroy the knob. Have a nice day.
Best regards,
Rosener Guyano
Posted on Feb 02, 2008
6ya staff
SOURCE:
Why does the paper jam and a loud noise come from the iP90 printer?
Most likelt to be a foreign object or wad of paper crammed into part of the paper feed roller. The first thing to do is turn it upside down and give a few sharp solid taps on the bottom casing. Then check to see if anything falls out. Also check the leading edge of the paper that didnt go through for marks that might show where it was stopped. If you are sure there is nothing to stop paper feeding through, check at each end of the print head path inside for a clump of ink soaked paper - remove if found. Try feeding a sheet through again. If the paper doesnt feed, try slipping a thin stiff card or plastic sheet back through the feed mechanism from the front. If that doesnt go through, you will have to disassemble the printer to find the problem.
Jun 27, 2014 | Canon PIXMA iP90v Printer
2003 Mitsubishi Outlander Grating Noise, Front Struts?
It very well could be the strut.
smaller chance could be the CV axle.
Also have the splash guards/heat shields checked to make sure they are all tight in place.
Mar 18, 2014 | 2003 Mitsubishi Outlander
Hp 4240n
mechanical check
Dec 18, 2013 | HP LaserJet 4240n Printer
My washing machine is very noisey.
Hi
Given below are the reasons of a noisy front load washer. Please check this link to get a detailed idea about your issue, it will help you troubleshoot your problem:-
http://www.doityourself.com/stry/front-load-washer-problems-loud-noises
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 07, 2011 | Hotpoint WMA35 Front Load Washer
Avid juicy ultimate, rear disc brake vibration and noise
It is a lose bolt somewhere, OR somebody has touched your rotor with their hands OR there is oil in the pads.
Check ALL your bolts for correct torque, buy new pads and Rubbing Alcohol and install them AFTER you clean off the rotor and your hands with the Rubbing Alcohol. TRY not to touch the rotor or the pads with your hands.
Dec 30, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Dryer makes loud sound while running sounds like a bearing
a lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
Dec 12, 2009 | Whirlpool ET8CHEXSQ Dryer
Noisey pump
Probably wear on the pump impellor, the only solution would be replace the pump, once you have made sure that there is nothing in it that could cause the noise.
Please rate my solution.
Thanks.
Oct 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Manuals parts listing
hi,
Here are the manual links it will solve all your problems..
Click on the first and second
first
Second
You need to have adobe acrobat reader to view the manual in pdf format.
Click here to download it if u don't have..
Goodluck,
Don't forget to arte me as fixya..
Feb 01, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
206 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
