Question about HTC Touch P3450 Smartphone
PHONE DOES NOT RING
DEAR SIR I AM UNABLE TO RESOLVE THE PROBLEM FOR THE PHONE NOT RINGING THE MODEL IS HTC TOUCH DUAL. HEADSET WORKS FINE . BUT WHEN I REMOVE THE HEADSET THE AUDIO OUTPUT IS NIL
  • 4 more comments
  • GilbertLau Feb 21, 2008
    same thing happened, it vibrate but not ring when incoming call
  • Anonymous Mar 23, 2008
    SAME PROBLEM MY PHONE REFUSES TO RING I RETURNED IT TWICE AS SPRINT STATES THERE IS A DEFECT
  • onaelw Mar 26, 2008
    I have the same problem, but with the HTC Touch
  • mrmg Jun 07, 2008
    my phone does not ring, but instead goes straight to voicemail. i initially fixed the problem by updating the software, but now it has returned a month later.
  • Anonymous Oct 11, 2008
    My ringer stopped working as well the sound has failed completely, as well as my faith in the quality of HTC products in general.
  • Anonymous Oct 15, 2008
    We have the same problem. Received the new phone today and it hasn't rung once. The calls just go through to voicemail but we can't find voicemail either!
My phone wont ring it just frozen what do i do
Posted on Jun 13, 2008
PHONE DOES NOT RING
This might be due to the settings....
Ringer settings
To change the ring type and ring tone
1.
On the Phone screen, tap Menu > Options > Phone tab.
2. In the Ring type list, choose whether to be notified of incoming calls by a ring, a vibration, or a combination of both.
3. In the Ring tone list, tap the sound you want to use
You can find more information at the manual located at the below location.
http://www.htc.com/support/pdf/htctouchdual/NIKE_HTC_English_Manual_16-KEY.pdf
Refer the pages 33 & 83
I hope it will resolve your problem...
With Regards,
TPV
Feb 03, 2008 | HTC TYTN GSM Phone
I would just like to ask on what to do regarding on sim card missing. the sim works just fine with the other phones. i have tried several sims with the htc touch P3450 but it does not read the sim. it...
You have purchased a htc handset which will work only on a particular service provider like AIRTEL OR VODAFONE,
check your default internal memory ringtone section , whether it has airtel ring tone ....
then by that service providers SIM CARD , your hand set will work.
some times dual band sim cards dont work on triband service providers.handset
Aug 19, 2010 | HTC Touch P3450 Smartphone
Facing peculiar problme with my HTC Cruise Phone
Hi Nitin,
Select the network manually and try if other parties are able to reach you without any trouble.
Jan 08, 2010 | HTC Touch Cruise Smartphone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
May 21, 2009 | HTC Touch Cellular Phone
HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Feb 10, 2009 | HTC Touch Diamond Smartphone
Phone doesn't ring for an incoming call
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
476 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
