Double channels coolstat 5000
How to I correct doublel channels on a coolstat 5000 plat. Fo example I have channel 205 one naming Fox the other 205 named unknown. This has occured throughout the entire system. It occured after I downloaded fiix 163
  • Ken Schmit
    Ken Schmit Feb 02, 2008
    Don't know what you are talking about. There is nothing in any of the set up or other programs in the 5000 that refer or relate to your suggestion. There likewise is nothing in the 5000 manual referring to your sugested fix.
  • 749 Answers
Maybe the system has reached the maximum channel capacity and it repeats some channel to have all the incoming signals... Have you tried re-channeling the system.. this will arrange and sort out the numbers...
Good luck... Fixya.
Posted on Feb 02, 2008
  • Rommel Balcita Feb 04, 2008
    Can you remove the downloaded fix 163... I hope that will remove the redundant channels...
I can get all local channels with my outside antenna but not the fox channel? Any idea what is wrong?
fox channel is a pay channel so unless you have paid and got the details , it will not connect
Apr 30, 2018 | Televison & Video
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
Vizio lcd retained channel info from former location
You will have to let the TV autoscan or autoprogram for channels again to fix this issue.
Aug 14, 2009 | Vizio VW32L 32 in. LCD HDTV
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Figuring out the TV channels for Comcast using the Sharp remote
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
Jan 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
Half way through a replay picture froze and would not recover. Then all channels vanished. Will not tune any digital channels now. Substituting a Freeview box onto same antenna cable tuned fine so there is...
left the unit fo 24 hours, reconnected it just as before and did a channel search (scan). Up came all available channels, recorder also appears to be fine. I am utterly mystified as to how a genuine fault condition one day (triple-checked for sanity) can fix itself. Fix double-checked to ensure AOK. Crazy.
May 07, 2008 | Mustek Televison & Video
Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Double channels coolsat 5000
delete channels and rescan it worked for me
Jan 30, 2008 | Audio Players & Recorders
Ram can works dual channel
you need to make sure your ram is identical.....for example if you have one single/sided and one double sided but are both equal in capacity still may not work.......also you could be using wrong memory slots double check your motherboard manual and ensure you are using correct memory slots for dual channel operation...however memory pair mismatch is most likely your culprit
Dec 12, 2007 | Intel D865GBF Motherboard
49 people viewed this question
 Grubhead
Grubhead
