HP Printer Reset
I have an HP Photosmart C4385 All-in-One printer. I always try to refill the cartridges when I can, to save a lot of money on new cartridges. However, I always seem to have a problem with the estimated ink level monitor. It stays at the minimum level, even after the cartridges are refilled. Can this particular printer be reset after the cartridges are refilled?
  • 1 more comment
  • Dennis Carey Feb 03, 2008
    Does each cartridge have it's own unique ID that allows the printer to reset every time a new cartridge is replaced?
  • Dennis Carey Feb 04, 2008
    An engineer at work told me that the only way is to reprogram the flash to default.
    He said he designed a JTAG for his HP printer and just saves the original bin and reprograms the flash every time he needs to replace the cartidges. His next step is to figure how to edit it, so he doesn't have to redo the settings.
    This method didn't work for the particular printer I have. I didn't check for an onboard battery that maybe used for backing up the CMOS and storing printer settings and possibly cartridge serials. This maybe something to explore also.
  • 749 Answers
Just keep using it... even though it's low-ink. If you have an old cartridge but has no ink, you can use that to full the printer... just place it and after that, return the one that you are using....
It works on my HP printer... Fixya!
Posted on Feb 02, 2008
    Genius:
  • 1,226 Answers
That is the problem of the refill ink, there is no problem about that howver you don't when it become empty.
maybe you cure that uninstalling and restart. after restarting reinstall back the printer driver.
note: disconnect the printer when installing the driver.
  • 1 more comment
  • Emelio Navaja
    Emelio Navaja Feb 03, 2008
    Maybe, because when the cartridges become empty, the system recognize it as empty, when you remove that and refilled, and then insert it back to the printer. the computer become confuse because it was recorded maybe in the memory that it was empty. Therefore the system always pop-up as low empty ink. If you are sure that, that is not empty i guess no problem but i don't know await later. However if you don't want to be annoyed by the pop-up window then maybe you can do the solution above. thanks, melnavz
  • Emelio Navaja
    Emelio Navaja Feb 04, 2008
    I do research on HP printer hope this help.
    Please refer to this site: http://www.misterinkjet.com/hpreset.htm
    and some testimonial in resetting the prineter.
    http://land.netonecom.net/tlp/ref/letter...
    Hope this help you.
  • Emelio Navaja
    Emelio Navaja Feb 05, 2008
    Ousted this specific printer, i don't stop digging solution i will notify you if in case i found solution. thank you. melnavz
    Genius:
  • 3,422 Answers
Resetting the printer can resolve several issues that may emerge. All the steps in the two sections below must be followed completely and in order for these resets to work. Performing a soft reset A soft reset, also known as an Electrical reset, can be used to restore the printer to a ready condition when a cartridge, paper, or other printing issues occur. This reset method should be used for the HP Photosmart 100, 130, 145, 230 and 245 printers. Perform a hard reset for all other HP Photosmart printer models.
  1. Disconnect any USB cables attached to the printer and remove any memory cards from drive bay.
  2. Restart the computer.
  3. Unlock the ink cartridge locking clips.
  4. Remove all ink cartridges.
  5. Lock down the ink cartridge locking clips.
  6. Close the main printer door
  7. Turn the printer off with the Power button and wait for the printer to shut down before proceeding to step 8.
  8. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  9. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer.
  10. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable.
  11. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error.
  12. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  13. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  14. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  15. Test for printer functionality.
Performing a hard reset A hard, or mechanical, reset is performed when the printer is in a condition where its normal printing process is interrupted. Examples include a paper jam, carriage stall, or mechanical noise. To perform a mechanical hard reset, follow the steps below.
  3. Remove any paper from the paper tray.
  4. Unlock the ink cartridge locking clips.
  5. Remove all printer ink cartridges.
  6. Lock down the ink cartridge locking clips.
  7. Close the main printer door.
  8. Turn off the printer using the power button and wait for the printer to shut down before proceeding to step 9.
  9. Unplug the power from the back of the printer.
  10. Unplug the power adapter from the wall outlet.
  11. Remove the rear access door.
    NOTE: The clutch is located in the same place as pictured above in Figure 1, however, you must access it from the left, just above the paper output tray.
  13. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  14. Release the clutch and roll the wheels up two more rotations.
  15. Locate and then roll the internal rollers in an upward direction until a clicking sound is heard.
  16. Reinstall and lock the rear access door.
  17. Connect the power adapter to a wall outlet.
  18. Reconnect the power cable to the printer.
  19. Turn the printer on.
  20. Re-insert the paper into the input tray.
  21. Wait for the appropriate missing cartridge error to verify that the printer recognizes this error.
  22. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  23. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  24. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  25. Test for printer functionality.
Goodluck,
And please don't forget to rate me as fixya..
  • 1 more comment
  • Priya darshan Feb 02, 2008
    Above is the pic of the clutch..
  • Priya darshan Feb 03, 2008
    Ya,theey do have their own unique id..
    Please do the steps whatever i have postd and ur problem will be solved..
    Goodluck once again
  • Priya darshan Feb 04, 2008
    he may be right but do try all the methods i mentioned above this mostly solves out many major problem..
    If still there's no change then i suggest u to call that engineer and fix it..
    Hope ur problem gets solved soon..
    Goodluck,
    please don't forget to rate me as fixya for my efforts..
Can I use ink cartridge 94 and 97 for a C4385 HP photo smart printer?
Unfortunately no....the HP Photosmart C4385 printer uses HP 74/75 (or 74XL/75XL) ink cartridges. However, you can get your cartridges refilled at most Costco stores or any Fry's Electronics store at a fraction of the cost of a new ink cartridge.
For additional printer help or advanced HP printer diagnosis for you specific printer model, please visit Inkjet411:
http://www.inkjet411.com
Aug 29, 2013 | Office Equipment & Supplies
My hp photosmart c4385 all in one says the ink cartridge is not in but they both are
Try to take out cartridges and check the chip. Maybe it is grimy. Clear it with cotton buds soaked with ethyl alcohol or vodka or some strong alcohol. Clear also the connectors in the printer.
Put the cartridges back.
Good luck.
Aug 21, 2012 | HP PhotoSmart C4385 All-in-One Printer
How to convert photosmart printer cartridge to refillable one
Yes conversion kits are available. I always recommend using a brand specific kit rather than the universal.
One company 4InkJets, claims that, "Our HP Ink Refill Kits are not universal kits. Each Refill Kit is specifically designed to work with a specific HP cartridge. Our refill kits are the best way to save money and still print at high quality. All of our HP Ink refill kits are dual refill kits which means you can fill up your cartridges twice. We also have clear and easy instructions on how to refill your cartridges. Our refill kits are backed by a one year 100% satisfaction guarantee."
You can reach them by CLICKING HERE:
CLICK Below for a video presentation on how the deed is done.
May 02, 2012 | HP Office Equipment & Supplies
What is problem when a ink jet printer (hp psc 2410xi photosmart) has a red stripe in the black print?
Using HP56, 56 cartridge for your printer?
Well, when you are out of black ink, that's what it happens.
Pls refill your cartridge or replace with new one.
How you refill? very easy.
f you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Office Equipment & Supplies
Red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
Hi I have an HP Photosmart C4385 that I bought in Us some years ago using the cartridges 74 and 75. I'm living in Europe today and I bought the cartridges 350 and 351 since as mentioned in the lable is...
Contact HP. Your printer needs to be reset to work with the European cartridges. If your printer is no longer in warranty, check the warranty on your cartridges and contact HP for warranty support on your cartridges.
Here's a link to contact HP. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&dlc=en&cc=us&product=3651156 This is a US link - you may want to start with www.hp.com/cposupport and after selecting your country / language, find a contact HP link.
I am an HP employee. I do not represent HP on this site.
Sep 15, 2010 | HP PhotoSmart C4385 All-in-One Printer
Printer problem
Quality refilled HP 02 cartridges should function in the same way that the originals did. If they are not, you've been had. These cartridges have kill chips on them that need replacing. Many "discount" refillers will sell you a cartridge with either the original spent chip or a very low quality replica. A reputable refiller doesn't make any money on the 02s but will offer them for convenience anyway.
Feb 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
295 people viewed this question
jasbo
jasbo
