Question about Maxtor Hard Drive
Dual boot/hard drive seetings
I'm adding an internal hard drive to my pc. I want to set it up for dual boot with media center on the original hard drive. And XP pro on the new drive. The original drive has two jumpers & they're set for master.The new drive (Maxtor) has one jumper set for cable select, but also has an extra jumper in the package. After reading the instructions,From what I can figure is to install the extra jumper on the maxtor & set it to the cable select diag. on the original hard drive & do the same with the original drive so that both drives are set to "Cable select" with "Two Jumpers". My reason for doing this is to run Pro Tools 7.4 which has conflicts with Media Center,My original operating system. So I'm adding the maxtor to to run XP Pro for Pro tools on a dual boot system. Is this the correct settings for the Jumpers on the Hard Drives. Please Help!
  • Anonymous Mar 26, 2014
    set it to cable select
  • 749 Answers
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Posted on Feb 02, 2008
No sound device, just multimedia device after adding a new hard drive and Windows XP reinstall.
Are you booting in from one of 2 hard drives at start-up .. ie. do you have a dual-boot system?
If your sound works fine when using the original hard drive but not when you boot from the slave, then it sounds like a driver problem -in the slave. You'll need to download the sound drivers for XP/Slave.
I can't think of any reason why your computer should beep after you have opened and closed the case. I don't think it is anything to do with the case. It's more likely that there's a bad connection or fault (maybe you have the slave and master on the wrong cable) - or badly fitted RAM.
Count the error beeps - there is a pattern of long and short beeps. You can find a list of their meanings here:
http://www.pcstats.com/articleview.cfm?articleID=1223
Though having said that, I would hazard a guess that you've got the master/slave configuration wrong. If you have both hard drives on one cable (ide) the MASTER drive should be at the end of the cable.
Remember there's a primary master (c) and a secondary master - your dvd drive. A 2nd hard drive would be set up to be the primary SLAVE. You cannot have 2 'master' drives on the same cable or bus. That would cause an error beep ...
Nov 28, 2013 | Packard Bell iMedia Computers & Internet
My HP media center Running windows 7 says BOOTMGR missing on start
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps you
Feb 25, 2012 | HP Pavilion Media Center TV m7480n...
Pxe-e61 media test failure check cable
The PXE error message suggests that your computer is trying to perform a network boot which is why it is saying there is a cable issue.
Check your BIOS settings and disable the option to boot from the Network, plus check that the computer is configured to boot from a valid internal hard disk drive. It is Ok to have a CD or USB device listed ahead of the hard drive in the Boot order as this is normal to allow booting from CD or DVD media or USB devices.
Check that internal hard disk is operational, that the cables to it are firmly connected at both ends (the drive and the motherboard).
If you still have a problem, then provide more information on what symptoms or error messages your are seeing.
Jan 11, 2012 | eMachines C3070 PC Desktop
Dual Boot
I am assuming they are both internal hard drives, If this is the case, on the back of the hard drive itself, there will be a set of pins with a little plastic connector in between two of them. This connector selects the role of the hard drive.
You want to set the Hard drive which has the operating system installed on it to MASTER and set the hard drive you want to use for extra space as SLAVE.
This tells the computer which hard drive to actualy boot from. It is not possible to run to Operating systems at the same time.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
Adding RAM causes PXE-e61
Most likely you have a slow or dieing hard drive that is why when as you state you add correct ram upgrade the unit fails to boot.
skip the ram and replace your hard drive with a new ssd (solid state drive)
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/PXE-E61-Media-Test-Failure-check-cable-Ideapad-z580/td-p/1318353
Feb 16, 2018 | HP Compaq Presario V2403NR Notebook
Bios settings?
these settings are related for boot up troubleshooting....system need startup point that is called boot up point.. Now there is sequence for search for boot up device that contain boot up point These device consist of floppy drive, hard drive, cd rom, usb drive and lan.....so try to set your boot device priority with hard drive as first device....this will solve your boot up problem....do reply back
Oct 02, 2009 | Computers & Internet
Dell dimension e520 reinstalling the XP Media center
connect your hard drive to other computer and then have it clean by scanning with antivirus. and then copy the important files on it to the working computer. after copying the files thats the time to return back the original hardrive to the dell dimension and then reformat and reinstall the system again again. please use original operating from dell or what ever is applicable.
mlenavz
Jan 31, 2009 | Dell Dimension E520 PC Desktop
Acer Desktop Won't boot up with new drive
You need to go the bois settings.... be careful there of you don't know what your doing.
The smaller cable is SATA and the one you are trying use is IDE.. your computer is set to SATA primary drive. You need to go to advanced seeting and change some seeting around to accept the IDE as primary. Please be careful you could end up messing your system if you don't know what you are doing. Please all the changes when you make them.
Please me know if you need telephine support at the time you do these changes.
regards,
Philip
Dec 01, 2008 | Acer Aspire™ T180 PC Desktop
Adding second hard internal hard drive
Sure it will, put the jumper setting on the hdd to cable select mode.
Sep 01, 2008 | Dell Dimension 2300 PC Desktop
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
Maxtor Hard Drive Logo
215 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
