Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Leaking dishwasher
By Susietwigge on Feb 02, 2008
  • leaks intermittently. I removed the side panels and there is no sign of water in the base of machine. Door seal seams to be intact. What else can I check. Seal that needs replacing? Machine is 18 months old. seams to leak on the right side of the machine.
  • Please advise. many thanks.
My dishwasher showed the error code either OE or E1, I think it was more OE. I stuck my hand in the filter in the bottom of the machine and then it was okay but the next time it was used it leaked all over the floor.
My husband has had it on every side, found a small filter underneath which he cleaned and ran it empty and it was okay.
Filled it up with dishes today, it was okay until it started emptying. I think the leak is from the waste pipe but we don't know how to get to it. Otherwise it's okay.
Same Problem
Jan 29, 2009
-   KitchenAid KUDS24SE is leaking on the left side. Have checked everything out. Have utilized the same soap for years without any problems. Perhaps the soap manafacture has changed its formula, or perhaps it could be the door seals? This machine has been a good one and I don't want to replace it unless I really have to. -   Guest
Solution #1
posted on Feb 02, 2008
Somewhat Helpful)
willymik
Rank: Guru
Rating: 86%, 88 votes
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
Door will not stay closed unless latched. Spring and connecting doodads appear ok.
Answer
dishwasher will not turn on, it worked last njight but nothing today
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Van Nuys, CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
