Service When you insert dvd / cd it is displays loading continuesly and finally it says no disc
  • krkid01 Apr 02, 2008
    my rj4200 just quit playing while watching a vcd It was like someone push the slow motion button,i hit stop it did nothing i opened the door and reloaded it with another vcd that did play in it it just said loading the no disc.then i tried a karaoke cdg same thing.i had a dvd/cd cleaner i tried nothing works .please help.thank kathy reed
  • 54 Answers
Maam/sir kindly check the lens of your dvd player becuase it might be dirty thats why it cannot read,,,,,clean it using lighter fluid,,,,and try also some cd's after that thnkss and hope to help you!!!
Posted on Feb 02, 2008
DVD NOT RECEIVING DVD DISCS
Hello
The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Mar 02, 2012 | Jamo DMR 60 DVD Player/Receiver
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Loads then says "no disc"
possible solutions:
-insert disc with labelside up
-clean cd/dvd blanc surface with a soft fabric
-use cleaning cd to clean lens
-change pick-up laser (service issue)
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 27, 2011 | Memorex MVD2042 DVD Player
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
THE PLAYER DISPLAYS BAD DISC.
You have not said the TYPE of CD or DVD you are trying to play.
Your manual will clearly state what can be played and what cannot. ALSO, some mfg's like mine (samsung blu-ray) provided software or firmware updates you can d/l to flash drive or burn on cd and insert.
Check manual and your mfg websit for what's available.
May 20, 2009 | Cyberhome CH-DVD 300 DVD Player
My DVD player has worked excellently for almost 10 years. Uncertain if that's the problem. All the buttons on the remote and on the front panel seem to respond--one way or another. This is a Sony CD/D
by a new player i recomend sony,there still the best. dont waste your money on blue ray,they will be obsolete in five years and they are very slow,ie. loading and reading discs, i know i sell them
May 19, 2009 | Televison & Video
Player unable to load discs when inserted
http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Nov 09, 2008 | Philips Magnavox DVD/VCR Dual Player
Cyberhome CH-DVD 300 can't read CD
Why don't you call manufacture and see if can get service.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
Cd's are ok but no dvd's...
Had similar problem. Found the disk was not rotating. Adjusted the torque on the hold down screws of the drive unit allowed the disk to spin. Still had some motor noise, but DVD would load.
Apr 09, 2007 | Toshiba SD-2800 DVD Player
Problems finalizing discs
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Nov 02, 2006 | Toshiba DR4 DVD Recorder
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
