Question about Canon PIXMA MP830 All-In-One InkJet Printer
Service Error 5C10
What is this? How do I fix it?
I have the same problem! Error 5C10. How do I fix? please advise.
  • Anonymous Nov 10, 2008
    .. it doesn´t work... I still have this error code.....
    Scholar:
  • 41 Answers
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
Also, be sure that your scanner is UNLOCKED...
With the machine turned OFF:
Open the document cover, look on the tray where the glass is -- and then look to the LEFT side of the glass and you will see pictures of an opened lock and a closed lock and a little switch...
Make sure the switch is next to the UNLOCKED position.
WAIT 5 seconds or so and then turn the unit back on.
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 23, 2008
At screen displayed to come up error 5c00 requesting solution.
Posted on Jun 26, 2009
2 Suggested Answers
valeantudor
  • 787 Answers
SOURCE: Error message : service error 5c10 on a canon
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
or
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
Posted on Apr 05, 2010
Error 5C10
Hello and Welcome to FixYa!
Error 5c10 is ink absorber problem.You need to reset Printer Canon ink absorber. For this Follow the steps given below
  • Start with printer off
  • Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  • While holding the Power button, release the Resume Button.
  • Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  • Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  • Turn off the printer and turn on again
Error will be removed
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution helps you
Thank you for using FixYa!
Mar 02, 2012 | Canon PIXMA iX4000 InkJet Photo Printer
Error code 5C10
Hello thanks for using fixya
Go to Canon Online support site. Link is given below
After open it
Click "Service & Support tab". Now type "error code 5C10" Wait a minute now. Choose first result option and then follow the directions in results
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation before going to the link. IT IS GOING TO SURELY HELP YOU
THANKS & Keep Using Fixya
Click Here to go
Jan 29, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I am trying to print on my Canon MP830 and I have had two error messages. 5C10 and 5100. I don't know what these errors are can you please help?
There seem to be a number of involved suggested fixes for the 5C10 error code.
Please go to this web page, and click the "Service and Support" link.
This will display a "Please enter your question" field. Type "5C10" into the field and click the Search button.
The first entry displayed will be a link to "ERROR LCD: Error Code 5C10" -- click the link
Three new links will eventually display:
  • Press ON/OFF switch to reset the multifunction device
  • Removing paper jams MP800R / MP830 / MP530
  • The MP830 may require repair
Click each link to see if the solution provided is appropriate to your situation.
Jan 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5c10
This error is a message indicating print head/ink failure on the printer.
I would try the following 2 things:
1. replace the ink cartridges/print heads. test to see if the problem is fixed.
2. If this does not solve the issue, you may need to either send it to the manufacturer for repairs (if under warranty), send it to a local repair person to service- or look for a new printer to buy (which may actually save you money).
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Received a service error 5C10, what do I need to do?
No 5C10 code to refer. I assume your error is 5010. If yes, that's mean your scanner unit is not functioning well. Need to replace it.
May 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error message 5C10, won't print. Need locations
I think there was a broken pieces of hardware in the print carriage.
According to the Canon Center this one cannot be fixed. If your printer is under warranty, send it to them.
Read also this online user's guide for your machine.
www.yboyandrei.com/MP830_Err5C10
Please rate me if i am helpful to you.
Oct 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5C10
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detection problems
Mar 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5C10
http://software.canon-europe.com/products/0010326.asp
uninstall the software and download the latest software from the above side and install it
Apr 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA  MP830 All-In-One InkJet Printer Logo
832 people viewed this question
old marine
old marine
