Question about Dell 3100cn Laser Printer
3100CN keeps asking to replace black toner tried 2 new catridges!
For some reason after I installed a new black toner for the 3100cn printer it went through a really long calibrating cycle, and then said to replace the black toner, i tried another new on but after pulling out the newly installed one saw toner everywhere on the black toner cartridge, i replaced it with a new one and the same things happens, I have vacuumed out the entire printer and the same problem..!!!!
  • 6 more comments
  • downriver Feb 05, 2008
    i took out the toner and shook the blank out of it...make sure you put somthing over it... remove it from the bag and re install. it started to print after that
  • kim2510 Feb 18, 2008
    Dell 3100cn keeps saying replace black toner soon.
    Need help installing Dell 3100cn as a network printer on windows vista. I have an IP address but it does not recognize it when using the setup wizard.
  • exmonk1 Feb 25, 2008
    I've had the same problem. The 3100cn keeps asking me to replace the black cartridge even though I just put a new on in.
  • Deweyrocks Mar 13, 2008
    3100cn, replace the black toner cartridge and it prints a few pages fine then goes to "ready to print" with "insert black toner (k)" flashing below. Send a print job to the printer and it goes to "processing" then to "insert black toner (k)" and quietly and does nothing. Replace with another new cartridge, leave it out for 10 min., turn off the machine for 10 min, reinsert another new one and the same results.
    Been using Ld refills for a year now Ld is sending me the third free replacement. What do i do to fix this problem?
    Deweyrocks
  • jester77 Mar 14, 2008
    I have the exact prblem. Is there a fix?
  • SHoward Apr 14, 2008
    i have the same problem. i replaced this toner about a month ago and now its saying replace black toner.. i take it out, turn off the machine. then it still says it. i dont get it.
  • shift2drift6 Sep 05, 2008
    I have the same issue. I just bought a new dell toner and installed it into the printer but the Replace black toner message will not go away. When trying to print it says replace black toner.
    Problem Solver:
  • 8 Answers
Replace with correct chip if this is not OEM
Posted on Dec 08, 2008
We have several 3100cn were I work. One has the above symptoms: very long calibrating cycle followed by the replace black toner message. I thought I could fix this by exchanging cartridges between the two printers to find the culprit. No success.
I then started looking for mechanical differences between the two printers -- and noticed that the roller BEHIND the black cartridge (take the cartridge out, look into the printer, and you'll see a partially hidden horizontal roller, perhaps part # C5396 2nd Bias Transfer Roller Assembly) was much more wobbly on the bad printer. I've yet to replace it (does not look easy), but I think this is the culprit.
Posted on Jan 03, 2009
After installing the toner cartridge the replace toner message will reappear after the calibration sequence until you press the menu button on the front of the printer. After doing that the message goes away and you should be ready to print again.
Posted on Dec 13, 2008
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Jan 27, 2010 | Dell Office Equipment & Supplies
Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
Try the cleaning rod. visit: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
Cheers
Oct 22, 2009 | Dell 3100cn Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Hi, My Dell 3100CN printer is displaying "Change Black Toner." I have replaced the toner cartridge. The printer begins to calibrate for a very long time. When it finally finished calibrating, it return to...
There is a chip in each toner cartridge which tells the main machine something about how full it is. It may be that it tells it how full it is, or it may be that it tells it how many pages it has done. It sounds as if the new black cartridge has a duff chip, and is telling the main machine that it is empty. To test this, you can overide the message. 1. press on the menu button;
2. select configure;
3. select maintenance;
4. select non-dell toner;
5. set the value to on.
If that does't work, get back to me.
Tony Ludlow
Feb 22, 2009 | Dell 3100cn Laser Printer
LDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
Nov 14, 2008 | Dell 3100cn Laser Printer
Dell 3100cn printer trouble
this sounds like you might have 2 problems on you fuser is not getting hot enough to fully fuse the toner to the paper and two your black toner cartridge has been comprimised and needs to be replaced
Oct 16, 2008 | Dell 3100cn Laser Printer
Dell 3100CN w/new black toner cart reads "Black toner LOW"
service your printer and change roller taplon tape and fuser aseembley.
Oct 09, 2008 | Dell 3100cn Laser Printer
Dell 3100cn
I've the same problem with a 3000cn but on the black color. all other colors are great execpt the black one.
Any Ideas someone ?
Apr 02, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
1,214 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
