Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Magenta Color Doesn't Print
I have a Brother MFC 240C and the magenta has quit printing. This happened to another 240C I had and the Brother replaced it since it was under warranty. Now it has happened to the replacement.
I have refilled my ink cartridges. Could this be the problem? Is there a way to clear blockage?
Thanks for your reply.
  • 1 more comment
  • sjspalding Feb 05, 2008
    I tried what you suggested and still no magenta. I even replaced the magenta cartridge and cleaned inside the printer where the cartidge plugs in and still no luck. I am at a loss now as this cartridge affects every color printed except black.
    Thanks for trying.
  • dacrmn Apr 26, 2008
    I have had the same problem with both of my printers too, with the same # printers as you., I dont have $200 for another printer everytime the majenta ink decides to quit printing......................dac
  • bhingo Nov 05, 2008
    Magent stopped printing.
    No error messages.
    Total sudden stop - no trace of magenta.
    Have tried 6+ cleaning cycles.
    Still no magenta in test or graphics.
    Dismantled similar to
    but removing final printhead to clean is different. Cant see how to get print head out of cleaning station and off machine.
How do you clean the head? is it the small white pad when removing the cartridge? dac
Posted on Apr 26, 2008
  • 37 Answers
Refill ink cart can be problem here, print head may be blocked , try cleaning the head in warm water
Posted on Feb 02, 2008
My brother mfc j220 canoot print magenta color although on the display the magenta is full i clean many times but when i test print i didnt see dotted magenta. what can i do?
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 06, 2011 | Brother MFC 210C All-In-One InkJet Printer
My Brother MFC-490CW prints magenta where it should be printing black. I have done numerous cleanings and alignments. I changed the black cartridge and it is a Brother cartridge, not a refill. Still...
Well, either your print settings have it set to print in a color model that is not the native one (I can get this from CUPS drivers by picking KMCY instead of CMYK, among others) or it is confused enough to need Brother's initializing tool (program, I mean) to get it sorted out. Try de-weirding your settings first, then double-check the print dialog's settings when you retry. Nobody loves magenta-on-white for print.
Jul 25, 2011 | Brother MFC 490cw Color Inkjet...
Have a MFC-240C used INNOJET compatible cartridges. display said magenta empty, opened it up, cartridge had leaked. replaced with new INNOJET. No magenta ink is printing. CLOGGED????? what to do? THNX
Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Brother MFC 240C All-In-One InkJet Printer
I cannot get the mfc-240c to print any red color (magenta)
A: run the cleaning routine
B: Replace the red cartridge
C: remove red cart. clean contacts, replace red cart.
Oct 19, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-240c
The digital display on the printer will tell you which color is low and when it needs to be replaced, either black, magenta, cyan, or yellow.
Oct 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Magenta goes bad
you guys are a joke! I thought that you really did want to help not get money from me. You let me down.
Dec 12, 2008 | Brother MFC 240C All-In-One InkJet Printer
MFC240C - all printouts in green colour
green is a combination of Yellow and Cyan, it is possible that you are missing magenta, depends on the file you are trying to print, if you can print one of each color this time print only magenta it would be helpful to isolate w/c is w/c from there you can find out what is the problem
hope this helps
Aug 08, 2008 | Brother Multi-Function Center MFC-240C...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
MFC-240C colr problem
No. Just buy original carts and install them. Run the manual cleaning procedure twice. Wait overnight and repeat the manual cleaning again. Should work. (..and give the compatible ones a dump)
Jan 16, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
488 people viewed this question
James Cagle
James Cagle
Jim Keysor
