Question about Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard
No screen i can't get a screen to work on my gigabyte ga-7n400 pro
  • snarly1 Feb 02, 2008
    there is no signal coming from the motherboard at all
    when i turn on the computer there is one 2 second beep then a pause then another beep then pause and so on
    Novelist:
  • 113 Answers
Have you tried resetting the bios? Assuming the video (or other part of the mobo) is not physically bad, it could be that the onboard video is disabled. Or you could try an external card, AGP assuming there is a slot, or PCI if not. Hopefully that would tell you if the motherboard was working.
If you are already trying an external card, it could be the problem. Perhaps trying a different card, a PCI one if the one you're having problems with is AGP, or vice versa.
One last possibility - on some older motherboards there could be a jumper that disables onboard video. If that is the case it should certainly be listed in the manual.
Posted on Feb 02, 2008
  • Phil
    Phil Feb 02, 2008
    One beep is usually a problem with either the memory or the video card. If you have 2 or more memory sticks, take out all but one, and if the problem persists, try each stick on it's own, and each stick in each different slot.
    If that does not help it could mean that the memory is bad, or the video card is at issue. Then try a different video card and see if that helps.
  • 749 Answers
Can you hear a beep when you switch on the computer? That's our clue... so give us, is it long or short, how many, and what is the sequence.... example "1 long beep, 2 short beeps" means a problem with the BIOS IC.
post me back....
  • Rommel Balcita Feb 04, 2008
    Okey... sounds like a memory problem.... memory is faulty...
    Trust me on this secret....
    (Don't forget to turn off on every removal and insertion of memory)
    Remove the memory and clean the contact points with a pencil eraser...
    Properly insert them back... try switching it on... If you still hear those sounds, find which memory is faulty if you have two. Insert just the first one and turn the PC on... then do the same on the second memory...
    If you still hear those beeps... well try a new memory...
    That will fixya the problem.
Do gigabyte motherboards GA-7N400 pro2/GA-7N400/GA-7N400L support usb3 cards
Yes, but please make sure you buy the PCI interface version, some of available USB 3.0 card in the market are mostly PCI-express interface. Just tell the store you will install it on the old PCI slot (white one). You also ask them if they have issue with the card that they recommending to you.
Nov 04, 2011 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Do you give me a list of gigabyte ga-81rm memory suppor ?
307_sub.jpg GA-7N400 (rev. 2.0)
  1. Supports AMD Athlon™ XP 400MHz FSB processor
  2. Supports Dual Channel DDR400 memory architecture
  3. Supports AGP 8x interface for outstanding graphics performance
  4. Integrated 6-channel AC'97 audio with S/P-DIF function
  5. Provides 6 USB 2.0 for high-speed connectivity
Oct 12, 2010 | Gigabyte GA-7N400 Pro Motherboard
Looking to upgrade my ram on on ga 7n400 pro mother board and was wondering what is the best to get?
see a professional or read the manual for your motherboard because every motherboard has its maximum capabillities
Sep 26, 2010 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
GA-7N400 Pro2 - GIGA-BYTE i need motherboard driver
can you try this link below:<br /><br /><a href="http://www.driverstock.com/GigaByte-GA-7N400-driver-download/30-9-8109/index.html">http://www.driverstock.com/GigaByte-GA-7N400-driver-download/30-9-8109/index.html<br /></a><br />hope that was helpfull<br /><br />
Aug 30, 2010 | Gigabyte GA-7N400 Pro2 Motherboard
Final video card upgrade for "GA-7n400 Pro"
Hi
Thank you for your query
Looking at the specification of the motherboard, the maximum you are looking at is 512MB AGP card (Nvidia or the like), unfortunatley i cannot tell you exactly which one, as differnt cards are used for different things i.e. gaming, web creation etc etc
Feb 12, 2010 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
No screen
HI I'm mhel , try to replace your memory card (RAM) with a new one this should do the trick.
e-mail me if this help
mhel
mijamhel@yahoo.com
mhel_services@yahoo.com
May 31, 2009 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Gigabyte GA-7N400 Pro fan makes tick noise after shutdown
i have a tick sound everytime my computer is on use.
Dec 26, 2008 | Gigabyte GA-7N400 Pro Motherboard
hi
clear your bios setup with jumper settings.
or
take your cmos cell 15 minutes then put in position.
also check smps.
power cable,power supply.
Mar 26, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Where to find manuals & Drivers
Here is the link for the drivers, bios, manuals, etc of this motherboard.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1756
Good luck
Lolita
Nov 01, 2007 | Gigabyte GA-7N400 Pro2 Motherboard
Gigabyte GA-7N400 Pro 2 : ATX Socket A FSB400 DDR400 AGP8x SATA/IDE Raid w/audio Gb-LAN (NEWITEM121760113) Motherboard Logo
112 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
