Question about Dishwashers
No water on wash cycle
I have a Bosch SMU 2000 series dishwasher . There is enough water for the pre wash cycle but once it gets to the wash cycle there is not enough water. If I put water in the bottom of the dishwasher it will wash good and then when the timer turns to the rinse mode there is plenty of water. I checked the screen on the inlet and it is okay, since there is only a lack of water on the wash cycle is it possible the timer is faulty.
    Genius:
  • 1,003 Answers
YES YOU ARE RIGHT TIMER COULD BE FAULTY OR WATER INLET SOLENOID COULD ALSO BE BAD
Posted on Feb 02, 2008
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Shx33a05uc won't start washing
bosch smu -4052 will not fill with water
Aug 08, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher is taking hours (at least 3 - maybe more) to complete a cycle. There is gummy, yucky stuff building up inside - sorta pinkish brownish. Could the water not be hot enough? A couple of...
if your on demand heater is one of the small ones that mounts under the sink, it will not flow enough water to fill your dishwasher. the dishwasher is waiting for the water level to fill before it starts washing. your bosch will heat its own water. hook it up to a cold line ahead of the water heater so that the fill valve is fed with full pressure. the residue sounds like detergent build up. when you get the water issue resolved, run a few cycles with no dishes and no detergent, on the highest temp setting. add a cup or two of white vinegar or dishwasher cleaner ( order online or get from an appliance repair store) through it. Dont forget your dishwasher has a filter in the bottom under the spray arm that needs to be cleaned periodically. if you dont clean it once a month it will get all kinds of nasty stuff built up in there.
Nov 20, 2010 | Bosch SHX46A07UC Built-in Dishwasher
Bosch SMU7052UC gets stuck in wash cycle. Pressing alot of buttons, on/off, I can move it to rinse where it sticks again. No drying either. Any suggestions?
I have a 10 year old Bosch SMU 7000 and the drying function has ceased. Dishes are wet after all cycles. From what Ive read this isn't worth fixing because Bosch are so difficult to get into.
Jan 23, 2010 | Bosch 24 in. SMU70 Built-in Dishwasher
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Cycle doesnt stop
STUCK TIMER MANUALLY ADVANCE TIMER THEY HAVE NOT MADE THE SMU MACHINE FOR OVER 12 YRS MIGHT BE TIME TO REPLACE MACHINE OR GET A QUALIFIED TECH TO LOOK AT
Jul 20, 2009 | Bosch Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher Model SMU 2046
First check the screen in the water inlet valve ( you have to take off the lower panel below the door and disconnect the water supply. If that doesn't work or isn't plugged, replace the valve.
Jul 09, 2008 | Dishwashers
Dishwashers Logo
289 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
