Question about Coby MP-C7085 MP3 Player
Problem with computer connection
USB device attached to this computer has malfunctioned and windows does not recognize it....it's a ccoby mp3 pmc7095 what should i do
My computer doesn't recognize the Sansa. Does any one have a
try this go to my computer then find hardware then click device manager find usb controllers then find the question mark then right click then properties the troubleshoot
Jan 07, 2010 | SanDisk Sansa e260 MP3 Player
My laptop does not recognize it (USB driver problem) ("USB device not recognized, one of the USB devices attached to this computer has malfunctioned and Windows des not recognize it...")
THE PROBLEM MIGHT BE IN THE DEVICE YOU ATTACHED TO YOUR LAPTOP.
IF THE DEVICE IS OK THEN THE PROBLEM IS IN USB PORT OF LAPTOP.
FROM MICROSOFT WEBSITE DOWNLOAD AND INSTALL (DISABLE PREFETCH), HOPE SO THAT IT WILL SOLVE YOUR PROBLEM
Dec 03, 2009 | Audio Players & Recorders
When I connect my Walkman to the computer it says USB device not recognized. One of the USB devices attached to this computer has malfunctioned and Windows does not recognize it.
use ipod in data dtorage mode when connected to your PC as if not connecting you might be having ipod driver you install it and you are on
Oct 17, 2009 | Sony Walkman NWZ-S616F MP3 Player
One of the USB devices attach to this computer
One of the USB devices attach to this computer has malfunction, and windows does not recognize it
May 12, 2009 | Samsung YP-U2 MP3 Player
Comp will not recognize Zen Sleek Photo, it says it malfunctioned
I had the same problem. I took all my router ports off and connected just my creative vision and it worked. System was over loaded.
Feb 22, 2009 | Creative Labs ZEN SLEEK MP3 Player
Help me
delete everything on the device as there is prob a corupt file that the computer cant read
Oct 29, 2008 | Apple iPod nano
Windows not recognised
Press and hold the lower volume button and plug it in to the computer simultaneously and keep holding the minus button until a box appears where the message of usb device malfunctioned and click on it. Then follow the instructions and it should be recognized.
Jul 11, 2008 | SanDisk Sansa MP3 Player
Tried the solution you offered for c240....
Go to Start --> Control Panel --> Printers and Other Hardware --> System --> hardware --> device manager --> right click on the usb port that is malfunctioning (should have a red or yellow exclamation by it), right-click it and click on Update Driver
If that fails, try another USB port on the computer to see if you have more success
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
Problems with computer connection
There's many reason that explain why a usb device can't be recognized by a computer, such as:
If it use to be recognized & function:
- Try the device on other computer, to check if it is ok.
- Try the computer with other device.
- Some computer virus can damage the function of usb device, if it is, try to clean up your computer and usb device.
- If you ever plug other similar device to the computer, and the device failed to be installed, then the computer will mark all similar device as unknown. Try to reinstall the driver, but remove the unknown mark first (plug the device, right click on my computer, properties, device manager, then find device with question mark or X mark, then uninstall it)
If it has never work with the computer before:
- Try other driver, contact the device vendor, or find in internet
Feb 02, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7085 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
