Question about Frigidaire Affinity ATF7000ES Front Load Washer
Washer shakes violently and loudly during spin cycles
Just ran my washer for the first time and it shook so badly loudly and violently it turned sideways and cracked the lightplate on the wall. It was just horrific. Did the person ( A DELIVERY COMPANY) not put somthing on it that should have been? Or did I just get a bad on, as of right now it's going back if I can't find somthing out. My set is up on pedastals.
  • Kathie33 Feb 02, 2008
    Thanks, this is what we figured...after looking further, my husband ,who was at work at the time it was delivered found out they were not secured in the back nor was it level and to top it off they were on the wrong bases!!! All leading to a damaged laundry room and the paint being scratched very bad. The set is going back to the BX in the morning, thank you!
We had the same issue. however, it was solved by removing for big screws from the back of the machine. if you look you'll see 4 screws with yellow covers that need to be removed. this solved the issue instantly.
btw, frigidaire's help line SUX.
Posted on Mar 21, 2008
There is a yellow tag on the back that indicates what bolts, spacers, and P clamp on the power cord that you need to remove. This information was not in the installation manual. They need to put tags on each bolt indicating REMOVE ME - the yellow tag looked like a utility tag on a gas meter that your not suppose to remove.
Dryer slightly dented and wall scraped due to violent episodes. My roomate and I had to wrestle the dryer during the spin cycle even on low.
lesson learned.
Posted on Nov 29, 2008
  • 2 more comments
  • bigseph35 Feb 04, 2011
    Wow that ish worked!!! My machine was slam dancing all over the laundry room. Now it runs smoothly, can't even hear it. Thanks
  • stfnwtl89 May 14, 2011
    Thanks - removing the bolts fixed the problem.
  • Pablo Gravas84 Jun 21, 2012
    I Me Tomo Una Semana Encontrar esta Respuesta Fue La Solucion OMG!!! work GREAT!!!!!! Very Helpful .. Thank You Sooo Much in High SPIN i can't hear any loud :-D soooo Haappy
  • jmshaw151
    jmshaw151 Jul 15, 2012
    thank you soo much!!! i'm waiting to see how well it works right now but hopeful :-) how many people returned these things because they ignored the instructions?? and you know what? if 99% of instructions weren't BS, people wouldn't ignore them!
Remove the shipping bolts from the back of the unit and you fix the viloent shaking.
Posted on Mar 27, 2008
THE WASHER SHOULD HAVE BEEN LEVELED WHEN IT WAS INSTALLED THIS SOUNDS LIKE THE PROBLEM
Posted on Feb 02, 2008
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Ge WASHER WHRE5260E shakes violently and makes loud noises during spin cycle
the cloths in the washer needs to be ballance... too much load on one side
Nov 14, 2010 | GE WHRE5260E Top Load Washer
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
It shakes so violently, it knocked 2 holes in the wall. During the spin cycle, it also turned completely around backwards!! It's so loud it practically shakes the whole house.
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
Nov 06, 2009 | Frigidaire FTF2140F Front Load Washer
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
3,521 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
