Philips 60 rear projection hdtv looks 3D
A large speaker was too close to my tv and it seemed to have thrown off the color on my tv. Everything looks like it is in 3D. How can I fix it. I think i need to replace the red bulb, because i took off the back of the tv and only the red seems to be the problem. So is it the speakers fault or is it the bulbs fault? I already tried to do the multipoint red/blue convergence and it didn't help. And if it's the bulbs fault, How do I replace it myself? Thanks.
  • engine_ear Mar 13, 2008
    I have the same TV, Philips 60" rear projection, with a similar problem.
    The red line is below the green in the convergence menu and will not move at all.
    I replaced both Convergence ICs and still have the same problem.
    Any ideas?
    Thanks in advance.
    John
  • 8,617 Answers
If your red convergence controls will not remove the red in all four directions, you have a faulty convergence IC. You will need to replace both. They cost around ten dollars each. Let me know if you need anything further.
Posted on Feb 02, 2008
Philip Rear Projection HDTV has a white shadow. The color is extremely off and we have tried to adjust everything. Any suggestions?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Dec 03, 2010 | Philips 60PP9202 60" Rear Projection...
Wavey line at bottom of tv
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments any where,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it reistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Philips 60PP9363 60" Rear Projection...
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202-17F Green and Red color across screen How can we fix it ourself
Hi dcwadsworth
What you seem to have is a convergence problem.
If you have a picture with something that looks like 3D effects then some parts will need to be replaced.
I`m leaving you an address where you`ll find everything you need;
http://www.tvrepairkits.com/xcart/home.php?cat=3651
The convergence kit is what you need.
In case you don`t have the tools to do it , you can find what you need HERE
Hope this help Good luck
Apr 17, 2010 | Philips 60PP9202 60" Rear Projection...
Picture quality of colours fading
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Philips 60PP9202 60" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
Philips tv top corners and bottom going 3d
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Oct 24, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence problem with Philips 60PP9352
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
