Samsung s42sd-yd01 plasma television wont power up
Turn power on tv reacts and goes to power up for about 4secs then red led alarm led comes on , tv then goes back to standby mode? any ideas to what i could check? thanks in advance
  • 3 more comments
  • Uncle-Rusty Feb 03, 2008
    Thanks rHogElz , Rear panel of tv set has been removed. Have check power going into the tv reading 243v , recorded this after the emi filter. power at the main module also reads 243v. There are 4 leds (3 green) (1 red) all 3 green leds light up when power is turned on at the wall, then after approximate 4 secs red led glows then a relay is triggerd turning the red and 2 of the green leds off. Any suggestions? am i over looking something?
  • Anonymous Feb 28, 2008
    Exactly what he/she said. Four LEDs First 3 green light up, then red comes on and two green LEDs turn off as does tv.
  • Anonymous Jan 03, 2009
    I HAVE THE SAME PROB .I FOUND IF IUN PLUGED THE BUFFER PLUG THE 3 GREEN LEDS STAYED LIT. I FOUND D8068 ON THE BUFFER POWER WAS DEAD SHORT . NEW PROB .
    THE DIOD IS SMD WITH NO ON IT L4 33 IF I MANGER TO GET ONE I WILL POST HERE GOOD LUCK IT MAY END UP ON EBAY.
  • Anonymous Mar 31, 2014
    all connections and power cords have been checked
I have also this problem 1 relay klikt than must klikt the second relay it do nothing
i see a few elco,s on the visibel boards who are dik the plastik is dik not the metal
to hot maybe
can this give the problems
somewone a solution for this tv ??
sorry for my bad englis
thanks
Posted on Aug 13, 2008
HI MY NAME IS COL, [email protected], I have the same TV with the same problem. It has something to do with a 'dew' sensor inside that trips it out when it senses moisture. It seems after a while the sensor gets carried away and cuts the unit out as it is with your TV. We found if you blow a hot hair dryer through the vents at the back for a few minutes, it will eventually come back on. Once the TV is warm the problem stops. I dont know exactly where the sensor is, and if you find out id love to know. Hope this is of some help. Also im trying to find a replacement remote for the same TV as mine is missing.
Posted on Jan 30, 2009
Hallo, der Fehler liegt auf einem der Boards und ist laut einem ehemaligem Mitarbeiter der Firma Innowert nicht reparabel weil es keine Teile mehr gibt, das entsprechende Board müsste erneuert werden. Meiner hat das gleiche Problem. Wenn man von hinten auf den Plasma schaut das Board mit der Alu - Abdeckung die man einfach abnehmen kann soll es sein. Bei meinem habe ich auf dem ganz linken Board vier defekte Kondensatoren entdeckt und werde ides mal erneuern, mal sehen ob es danach funktioniert. MfG
Posted on Feb 22, 2008
  • 54 Answers
Sir kindly check the power supply of it,,,thnksss and hope to help u??
Posted on Feb 02, 2008
6ya staff
SOURCE:
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Is there a troubleshooting guide for samsung model #s42sd-yd01?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 26, 2014 | Samsung Televison & Video
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
Plasma wont turn
unplug it and leave it off for 10 mins
then plug it back in.
Aug 18, 2009 | Televison & Video
Sampo PME-42S6 doesn't turn on
Same problem red alarm led comes on you need the power supply unit it's $139.00 you can fix it your self. And gateway dont have to parts i have a phone #
Dec 13, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Samsung s42sd-yd07
flat screen hisence keeps flsing red and blue but doen not go on until 20 min. can you help
Sep 05, 2007 | Televison & Video
Televison & Video Logo
1,740 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
