Question about Mitsubishi PD-4265 42 in. Plasma Television
Needing unlock code
A friend of mine has a mitsubishi tv i was needing to know how to unlock the channels. it turns on and everything but that seems to be the problem. they do not remember the code that they used so is there any way to find out what code was used
  • 54 Answers
Sir,,,,the only solution for that is using a computer,,,,thnkss and hope too help you???
Posted on Feb 02, 2008
MITSUBISHI tv model #WS-55809 HOW DO I UNLOCK PARENTAL CODE?
You would need a remote---with that if all else fails there is a way to release the parental control by doing a reset using the option menu, let me know as with the Mitsubishi remote and a 4 number code you can get to the OPTION menu and reset this set.
Nov 30, 2012 | Televison & Video
Mitsubishi ws-65313 always says tv will turn off in 2 minutes, how do you stop this
It may be the reason they got rid of it but the set should have a hidden menu called Option which will allow a hard reset of the entire set and should cure the quirk the set seems to have==going to need and have the Mitsubishi remote and a four digit number code to do it.
Aug 27, 2012 | Mitsubishi WS-65313 65" Rear Projection...
Need tv code, tv is locked
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
5
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Also note that forgotten the passcode of your Mitsubishi TV. You can make it alive without knowing the passcode. Please follow
V_Chip lock bypassing prodedure is as follows
You can view your locked TV, cancel the lock, or enter the V_chip lock menus.
This is done by pressing the number "9" and "QV" buttons on the remote TV control at the same time, when your passcode is requested. This process temporarily unlocks the TV.
When entering the V_Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
I hope this will help to solve the problem...
Aug 20, 2011 | Mitsubishi VS-60703 60" Rear Projection...
TV will not unlock channels over TV14
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
These steps are actually for the rear projection models, but I hope the work for dlp plasmas as well.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi
To unlock, using the Original remote, press 9 and QV (QuickView).
Then go to the main menu and select channel lock and turn that off. When it asks for a password, press 9 and QV again.
Bill
Dec 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Help! How can you unlock a pin on a TV that you don't know?
Tried unplugging it for five minutes then plugging it back in? It resets the software.
Sep 09, 2007 | JVC AV-27020 TV
Mitsubishi PD-4265 42 in. Plasma Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
