Question about ASUS ALi Chipset A7A266 (A7A226) Motherboard
Upgraded to vista. Not working
Mine is Ausus A7A266-E with athlon xp 1800+. Ram is DDR 512 MB. I recently installed vista ultimate. But after installation, while restarting after finalizing, the syatem gets repeat resets. I am not able yo get in to system. Kindly advise
  • 152 Answers
With 512MB it is not enough space for Vista to run with... i strongly advice you to use vista only if u have a RAM of 1GB and above....
i my sys the RAM memory usage always stays around 740MB... i'm using vista only....
Posted on Feb 02, 2008
How can i upgrade from windows XP professional to windows vista for free?
you can't the system resources on the xp pc required to run xp are a lot less than what is needed to run windows vista.
how much ram and how much disk space !
it says 512 Mb ram but it will run like a snail
15 Gig of free hard disk space and a 20 Gig hard drive
https://support.microsoft.com/en-au/kb/919183
DO you have an upgrade copy of Vista ?
Nov 14, 2015 | Microsoft Windows Vista Ultimate Edition
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
I want to play Fifa 09 on my compaq presario 2100 amd athlon xp 2800+ 2.12 GHz,448 mb ram laptop,but it does not open.I don't have any graphics card but I want to install one.Which would be the most...
Sorry to tell you this but this laptops video card is permanently attached to the mother board. So upgrading to a new one is no possible.
Sorry,
Armymason
Feb 27, 2009 | AMD Mobile Athlon XP-M 2800+, 2.13 GHz...
Which memory ram for amilo pro v7010
http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
Jan 31, 2009 | Computers & Internet
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Vista Ultimate
need at least 2 gig of ram and 160 gig hard drive to run vista
May 29, 2008 | Microsoft Windows Vista Ultimate Edition
Needed a video driver
as i think you will be knowing the minimum system requirement 4 windows vista it s 512 mb ram ..as i think ur s is less than that so you may be facing the hanging problem .. if so i suggest u 2 upgrade ur ram to minimum 512 .... r u install windows xp SP2....
if u have 512 mb ram then there may problem with operating system this may be due 2 d virus attack some files have became unstable ... so reinstall ur vista ....
your problem will be solved...
Feb 10, 2008 | Microsoft Windows Vista Ultimate Edition
ASUS ALi Chipset A7A266 (A7A226) Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
