Question about Mitsubishi HD-6000 DTV Receiver / Video Recorder
Mitsubishi WD65733 I hate this TV ~ I've had nothing but problems. Service company can't get it fixed. It turns off by itself all the time ~ red ligt comes on. You can reset, it will then turn back on ~ takes a while for the picture to show. Then it might last a day, or turn off again in 5 minutes. The service guy told me to push the menu and input at the same time, to get service code, but nothing happens. Can you help please. [email protected] Thank you..
I have this TV and the same thing happens to me as well. Only a month after I purchased it, it started it. Once it turns off with the red status light blinking, press and hold the two buttons for about 10 seconds. You'll then see the green light start flashing. It will flash two sequences. Mine always gives me a code 37.
One weekend, I couldn't get it to turn on for two days, and I was so upset since I couldn't get any service people on the phone. When I finally found a service company that would return my call, the 5th company I called from Mitsubishi's authorized service techs in the area, they scheduled a guy to come out. Eventually, before he came out, I got it to come on and stay on after countless resets. And of course, once he came out to the house we could not replicate the problem.
Since then, (about 4 months ago) it's worked perfectly until just last week it did it again. This time, I only had to reset it about a dozen times before it worked and has worked consistently since then.
It's really frustrating that the problem is inconsistent, and for some reason Mitsubishi claims to never have experienced it before. I do have the extended warranty, and at this rate, I'm assuming they eventually do a full replacement after the 3 service call "lemon" clause.
Oddly enough, after
Posted on Mar 31, 2008
  • David Jan 08, 2014
    Update after 5 years: Eventually, the extended warranty service replaced the entire TV. I was constantly requiring service techs to come out, and eventually the tech was able to get someone on the phone at the warranty office and they finally agreed it was better to replace. (On this service call, it was to replace the DLP chip itself.) Against my better judgement, I purchased another Mitsubishi (WD65738) which is basically the same model just with 3D functionality. I've had it for a couple years now and so far only had it do the reset thing a couple times. Otherwise, it's worked great. Still bought an extended warranty just in case, but this is my last Mitsubishi. I love DLP technology, but it's time to move on.
6ya staff
SOURCE:
I have a lg 65lb5200 tv that sometimes i turn it on and it has no picture.
It seems to me the tv is not getting enough power to turn on. make sure the tv is pluged into a surge protector and then to the wall. no power strips with other things pluged in. all by itself to the plug. you always want to put a surge protector on all the small and big electronics for if you do not if lightin come in it would burn everything up. you might have had ligting come in and that is why some of your stuff is having problems now. if you own he home get a whole house serge protector. it will save you in the long run becuase if there is surge from the power company or from lighting then all your stuff will be protected.
Aug 28, 2018 | LG Televison & Video
Mysteriously stopped booting up
I hate when people just guess what is wrong at sites like this, but I'm "guessing" your power supply needs to be replaced. I've seen similar symptoms before. They're cheap and easy to replace. I'm 80% sure that will fix your problem. Just make sure it has the correct standard or SATA power connectors for your hard drive(s) and CD drive.
Oct 07, 2012 | Asrock K8NF6G-VSTA Motherboard
My old Toshiba tv is stuck on widescreen, help..
this a problem with microprocessor signal, this will be difficult for to fix it yourself.
Every signal coming from tv goes to the CPU, you must have high skill for to repair and diagram. I can recommend you to get assistance from some repair shop TV for fix it. see the diagram and you will see the problem difficult.
God bless you
Jul 14, 2012 | Toshiba CF32F50 TV
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
19in LCD TV
Right now I believe the TV is in " Protection Mode ".
Try leaving the TV unplugged for 30 minutes, that way the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 06, 2009 | Insignia IS-LCDTV32 32 in. Television
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Sonykv-32v40 red ligt blinking black screen and soud good
Take it to a shop... It's a good bet that the jungel Ic, crt driver Ic or something in the HV has failed. Could be also that the crt itself is failing. If that's the case a tech can test it with a B&K and know for certain.
Also, if you want to save a few dollars take it in to them, don't make them come and get it - it just drives the price up for a pu/del charge.
Bill
Nov 24, 2007 | Sony KV-32S45 32" TV
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is [email protected]
Oct 31, 2007 | Sony KP-FX532M91 TV
KV 27S65 Sony Trinitron 27"
So far you have done all you can and you have done everything right. The fact that the TV turned off by itself and then turned back on by itself suggests that one or more solder joints have come loose inside the set. A qualified tech should find this easy to fix, and Sony sets are always worth repairing, so it is now time to have the set serviced by a tech experienced in Sony standard sets.
Sep 01, 2007 | Sony KV-36XBR400 36" TV
Mitsubishi HD-6000 DTV Receiver / Video Recorder Logo
202 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
