Question about Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset
Signal Issues I just got an H550 bluetooth the day before yesterday. Everything was working fine except none of my ringtones would work, so that was the first problem. Now it keeps cutting off my calls telling me the bluetooth signal is weak and to use the handset. This has been happening tonight, and the battery is fully charged so I am not sure why it suddenly has this second issue.
  • Tina K Feb 10, 2008
    I was wondering why my ringtones will not work when I'm using the H550? Is there anything that can be done about it?
I an thinking of buying a h550 bluetooth headset but dont know if i can put mp3 music into it or if it can use a usb to connect to the pc
Posted on Mar 08, 2008
Pairing my H500 with blackberry
Posted on Feb 12, 2008
Why do my all my lights work on my 2001 GMC jimmy except my low beams.
Replace the turn signal switch. All the exterior lights run threw it except the high brake light. There is a small plastic clip/switch in it that controls high and low setting. Because of heat it starts to melt and quits working.
Jul 05, 2015 | 2001 GMC Jimmy
Bluetooth connectivity issues
My router extender did that once. A simple powered down and restarted fixed it. I hate to sound like Comcast which always tells you to do that but it's worth a try with wifi and bluetooth. Also obvious but check the battery, when it gets low enough the signal gets weak before it actually stops. Cellular telephones do the same thing. A low battery can affect signal strength.
Mar 16, 2014 | Motorola Radio Communications
I need passcode to make my bluetooth work in my phone
I need the passcode for my Motorola H550 bluetooth headset?
Sep 21, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Pin for bluetooth h550
Try '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 17, 2010 | Motorola Mobility H550 - Bluetooth Headset...
My turn signals wont work right
replace the turn signal switch. or the turn signal assembly in the steering column
Mar 08, 2009 | 1996 Lincoln Continental
My motorola H550 headset does not work for my PS3
Go to Settings, then Accessory settings, then audio device settings. Now change the input device by selecting it and change it to the motorola H550. Save these changes and It should work. Did for me at least. If you're still having issues or not seeing the option for your Bluetooth device, try going to manage Bluetooth Devices and see about registering it there.
Jan 27, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Bluetooth
i use bluetooth all the time, and i'm registered on us cellular, and they restrict everything, except sending things via bluetooth. I can only send ringtones and wallpaper, and maybe that's all you can do too; because the files are corrupt, in other words-your phone doesn't support it.
Jul 28, 2008 | Nokia N95 Cellular Phone
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
Motorola H550 Bluetooth Headset
Here is the user manual for the bluetooth headset.
User Manual
Pairing with the LG will be similar, your bluetooth settings will be under settings and tools, and either under "bluetooth" or "connections".
Dec 22, 2007 | Motorola Mobility H550 - Bluetooth Headset...
Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset Logo
179 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
