Question about Philips PM-8FS LCD Touchscreen Remote Control
Got a Defective remote.
I just bought this remote yesterday and upon installing batteries I found that the display just shows jibberish. I have tried new batteries, and doing a master reset. Anyone have any suggestions on a possible fix. Thank you in advance. Chris :-)
  • Anonymous Jul 13, 2008
    Just bought the same product, and upon turning the remote on, it would randomly display stuff.
  • reinhardmoto Dec 06, 2008
    defective remote how can i get it fixed
How do you do a master reset?
Posted on Oct 01, 2009
  • 3 Answers
It sounds like weak batteries. Have you replaced them?
Posted on Nov 25, 2008
I have a Roland XP-50 workstation. A friend was playing with it and after he was done and I turned it back on The LED display said "User Memory Damaged"
As this appears to be a musical instrument not a camera, further information may be forthcoming if you post this query in a forum dealing with such items.
Jan 17, 2017 | Roland Cameras
The display feature suddenly went into some random state and nothing displays except jibberish. How can I fix it?
Try removing the battery for 15minutes or so. Let all circuits decay and then replace battery. This has worked in the past.
Jun 17, 2015 | Panasonic Kx-tc1703 Cordless Phone Battery...
HP LaserJet P3005 Printer will not print using a parallel cable.
# Switch off the printer, cancel pending jobs..Refix parallel cable both ends & tighten them Check proper drivers installed or not if not install proper drivers.. shoot print command. check..if not resolved...For tech guys:# Replace cable..checkRemove printer formatter, check any dry solder or pin breakage at parallel port.(show in snap shot), found... try to repair it or replace the formatter assm. Check system parallel port working or not...
Dec 30, 2011 | HP LaserJet P3005 Printer
I have a Sony CDP-CX350. I recently discovered the remote will not control anything on the player. The remote has fresh batteries and displays that a signal is sent out. The same display usually shows...
If you have turned it back on then this would indicate the receiving module that picks up the infrared signal is not working and has become defective, but I would double check your manual so nothing was over looked.
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
The little read out screen is showing jibberish instead of the date and time. It was fine yesterday. We turned it off for a few minutes, then we unplugged it for a few minutes but niether one fixed it....
Hi:
Open the cover that has the display on it and look at the backside of it.
You will see the display connector. Make sure that the connector for the display is plugged in securely, then turn the machine back on.
Andrew
May 11, 2010 | Toshiba DP-85F Fax
I got a used car last year with a Kenwood KDC-692 CD-Reciever installed. Yesterday, my battery died in cold weather. Upon jumping the car, the Kenwood asked for a security code. I have no idea what the...
ok this worked for the kdc-x693 I just did it.first you need the remote. then turn on the car and unit instantly hold the auto button down and rotate the right control knob clockwise untill the display reads this. security clear
code
just like that on the screen.then tap the 5 button on the remote.
that will scroll through the letters on the #5 button then push the >>button on the remote you need to spell kcar out on the screen.
Dec 10, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Remote does not work
try replacing the battery.
What I have done is open up the case and make sure all the water is dry. If not, use a hair dryer to dry it clean, being careful not to 'overheat' the unit in case you burn up any chips on the board.
If this does not work, replace it.
Feb 16, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Charging problems
The phone has manufacturing problem... if you have a warranty, then return it to the seller for repair or replacement, it free.
Oct 18, 2017 | Audiovox CDM8610VM
Philips PM-8FS LCD Touchscreen Remote Control Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
