IS IT THE LAMP?
HOW DO YOU KNOW IF THE LAMP IS THE ONE THAT IS NOT WORKING?
My TV won't turn on... I checked the lamp, it's not burned, and I also check the fuses, there were 2 really small ones, but they didn't look burned either.
I have a Hitachi 60V710.
  • 8,617 Answers
The lamp indicator should indicate when your lamp needs replacing.
Posted on Feb 02, 2008
6ya staff
SOURCE:
Problem with Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television. Does this indicate that the lamp is burned out?
if the lamp indicator is blinking and won't turn on which means you will need to replace the lamp.if you don't have an idea how to replace just leave it to the tv technician to fix your tv.
Sep 17, 2012 | Televison & Video
When I put in the new replacement, the tv won't turn on. All I get is a few short bursts of clicking and then it turns off. I think it is because the ballast is not seating properly, but am unsure...
Definitely lamp is not installed properly if TV was working fine before replacment.
Also check for wright part number on new lamp,or new one is defective.
Aug 15, 2011 | Panasonic TYLA1001 TYLA1001 Projector Lamp
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
Just replace the lamp.. there is a burning like smell, does anyone know what is causing this smell?
After the projection lamp was replaced the tv work fine right?The burning smell,is the burning carbon from the dead projection lamp.
Oct 06, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
TV turns off after a few moments but come back on again after a few seconds
Remove the lamp and check to see if the connections of the lamp and the lamp driver(ballast) are ok or they look bit burned.Also the lamp should always be replaced first especially if is two years old or more.
Check to see how many times the error indicator flashes.If it flashes 5 times then the lamp driver is probably defective.
common problems are lamp and lamp driver(ballast).
let me know if you need more help.
Good luck.
Sep 19, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
New Lamp will not come on
I suspect thermo fuse near lamp or ballast or light engine. In that order , first double check lamp is in tight and covers are on correct there are switches on cover for lamp.
1 thermo 150.00
2 ballast 250;00
3 light engine 600.00
Get a tv service center to come over and check. it would be worth the service call ask him what he charges for road call , at least know you have price and part information.
thanks doctor video
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
