Question about HP Pavilion zd8000 Notebook
My batterie is not taking charge
Pavillion zd8000 is just not taking enought batterie chrge i run a test its always showing 3% every time i enplug the note book it shuts off
hat shuld i do
    Genius:
  • 1,067 Answers
Buy new replacemnt batery 1st ok maby new adpoter power
Posted on Feb 02, 2008
Saab 93 1.9 tid warning battery not charging car died whilst driving charged battery at home car now starting lights all out is this battery prob or alternator?
The easiest way to check is with the car running, disconnect the positve side of the battery, if the car dies, then it is the altenator, if the car keeps running then it is the battery. If you have a volt ohm meter, check the chrge going to the battery you should get between 12 and 14 volts if it is lower than 12 you have an altenator issue. the altenator should always produce enough to charge the battery and run the car at the same time, if not then the battery wears down.
Mar 13, 2011 | 2004 Saab 9-3
Car wouldnt start yesterday jumped it it started tried to start it this morning and wouldnt start again.... altenator???
Once the engine is running the alternator takes over to keep it running while sending a chrge back into the battery to make sure the battery is charged back up enough to start the engine the next time. If the car continued to run for a while after you jumped it, it may not be the alternator.
If you can get it jumped again, let it run for 10 minutes or so, if it continues to run, it's not the alternator, but more likely an issue with the battery.
If the car is running okay once it's started, you may want to go to a local parts store and have them check the battery and alternator with a diagnostic system. Most of them do not charge for this test.
I hope this helps.
Jan 27, 2011 | 1995 Volvo 850
HP laptop dv2000 pavillion , power button lights on everything then beeps twice and nothing on the screen,I repair and changed the motherboard charged me $400 Then now again in 3weeks time did the same...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 23, 2010 | HP Pavilion zd8000 Notebook
Hi my battery only lasts up to an hour, how do i
Well it should last between 3-4 hours if new. <br /><br />Batteries need conditioned . You fully charge them and then run them fully down. 1 hour seems pretty short. As a rule, don't run them on battery while plugged into power.<br /><br />I have no better solution than this.<br /> <!-- from fixya rte -->
Aug 17, 2010 | HP Pavilion zd8000 Notebook
HP Pavillion zd8000 will not turn on?
1. take out battery
2. plug the unit in without battery
try to boot it like that. If that does not work you might have a bad power adapter or even a burned motherboard. We do not know unless you try these things.
let me know
please do rate this and leave feeedback
Jun 26, 2010 | HP Pavilion zd8000 Notebook
I have HP PavilonDv4000.My batery show charge 96% total time remaning 5min.I have new battery first chrge the battery fully.Second,discharge the battery completely.And this battery can't be charge any...
Try another known good working battery and if it doesn't charge and hold the charge properly,
If that doesn't work, try another know good working ac adapter to see if it is actually charging the battery properly.
If that doesn't fix it then you know for sure at that point the motherboard is bad.
May 31, 2010 | HP Pavilion zd8000 Notebook
Lights up then beeps twice and power button flashes but nothing on screen zd8000 pavillion
You can try taking out the memory and reseating it.
Majority of the time with the ZD8000 the motherboard has gone bad.
Feb 24, 2009 | HP Pavilion zd8000 Notebook
HP Pavillion zd8000
Ok the lines on the moniter means it is a bad screen that must be replaced and battery not working could be a few things it may be a bad battery or bad charging circuit to test this you can try charging another battery in your laptop and if it works it was the battery if not it might be the charging circuit.
Dec 04, 2008 | HP Pavilion zd8000 Notebook
HP pavilion zd8000, Battery not charging
The problems with the HP Pavilion (Particularly the ZD8000) are sadly well-known by HP. It's not a problem with the battery or the charger or anything you can easily fix. The problem is heat. If you search long enough, you'll find hundreds of people with three problems: 1) the battery stops holding a charge after about 8 months, they buy a new one and get the same problem; 2) certain keys stop working on the keyboard, they remove the battery and the keys work again; 3) permanent lines start to appear on the display and never go away.
Unfortunately, there is nothing you can do about these problems with the ZD8000, except stop using it as a laptop and ditch the battery. I have been problem-free since I ditched my third battery and just use it with a power cord.
Last year, I filed a formal complaint with the Better Business Bureau regarding HP's failure to acknowledge this problem and recall the machine. Each time I called service, I was instructed to follow the battery initialization procedure. All this does is allow support to get rid of you for 24 wasted hours, after which you have to call again and talk to some one new who tells you to do the same thing. The problem is, the procedure fails because the battery won't hold a chage in the first place. If you get to the end of the procedure with them after wasted days, they tell you to buy a new battery.
The HP ZD8000 is defective and never should have been released with a Pentium 4 processor. It's too hot and fries the battery and damages the screen.
Jan 26, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
