Question about JVC DR-M10SEF DVD Recorder
No SOund I have just collected my DVD recorder back from the repairer's after having the 'LOADING' problem repaired under warranty. I connected up the DVD to my stereo TV and everything was working relatively OK except some minor station-tweaking. I went to AUTO tune and I noticed a new menu had been installed (for European languages as well as English). After it tuned itself I then went to move the stations to their corresponding buttons, i.e. Channel 2 on button 2, etc. That's when I noticed the sound had stopped working. It was fine until just now. (Yes, I have checked that the TV's sound is OK.) I can play DVDs I have already recorded before today, but I cannot hear the TV nor record any sound.
  • 5 more comments
  • scotmr Feb 02, 2008
    The Audio settings available to me are:
    DIGITAL AUDIO OUT (which I don't have):
    • Dolby Digital/PCM
    • STREAM/PCM
    • PCM only
    ANALOGUE AUDIO OUT:
    • STEREO
    • Dolby Surround
    D. RANGE CONTROL:
    • NORMAL
    • Wide Range
    • TV Mode
    OUTPUT LEVEL:
    • STANDARD
    • Low
    The options in capitals are those selected.
    RE: Comment by djnick989, posted on Feb 02, 2008
    need to get digital cable use dolbe digtial out ok
    Can't use digital - incompatible with TV
    on anlog red white rca cable use sterio only in settings ok
    If you mean ANALOGUE AUDIO OUT setting, it is already on STEREO.
    STILL NO SOUND! :o(
    Using RCA red/yellow/white cable from DVD to TV.
    RE: did u hit button in ther called progresive scan ?
    I might have... I was trying everything to get sound, but after there was no sound...
    RE: ya if u did u have to use red green blue cable out of the back of dvd coumpunt cable to tv so u can see it again ok then defult it back thats why
    What's a 'coumpunt' and why a red green blue cable instead of a red white yellow cable when it was working fine just previously? And how would I get it to 'default'? Sorry, but I don't understand...
    But I can SEE it OK - I just can't HEAR through it. I can play DVDs that were recorded BEFORE I stuffed up the settings, but not now.
    Genius:
  • 1,067 Answers
Cheak sound output settings and cable to pcm not dolby digital
Posted on Feb 02, 2008
  • 7 more comments
  • nick helpap
    nick helpap Feb 02, 2008
  • nick helpap
  • nick helpap
    u odnt have cables or it dont have output digital ?
  • nick helpap
    what cable uusing from dvd to tv coumpount cable or yellow reg video cable
  • nick helpap
  • nick helpap
  • nick helpap
    mark this as fix ya
  • nick helpap
    becuse red green blue carrys progesive scan out put ok yello cant 480 i only
  • nick helpap
    is it on the right input with tv your using red white anlog out for sound does tv acept digital cable out go with that then or adjust adusio out setings in int to pcm only for now ok
I cannot see anything on the LCD screen or in the viewfinder. It doesnt record video but it recoreds audio
It sounds like the CCD or its circuitry has gone down. (CCD is the cell that receives the light through the lens and turns it into a picture). Only solution is a repair or buy a new camera. If it is still under warranty or very near it, take it back to the dealer, promise him you didn't drop it, and ask nicely for it to be repaired under warranty. If you are in UK, argue your consumer rights if the warranty has just expired - the consumer may reasonably expect an expensive device like a camcorder to last more than a year.
Aug 28, 2014 | Hitachi DZ-MV750MA DVD Camcorder
Disc tray cannot be opened
Hi, The unit is in initialization/reset mode immediately after powerup. It does a self diagnostic sequence. When a fault is detected, it actually locks up till the fault is removed/repaired. A couple of things you can do: 1. Unplug the unit from the mains for a couple of hours; 2. Check your manual if there is a hard/full reset sequence/button and perform it; 3. Remove the topcover and inspect the loading tray. There is a possibility that a CD is stuck, lodged or skewed inside; 4. There is also a possibility that the loading mechanism is stuck, defective belt/gear; 5. if the unit is still under warranty, require service or replacement; or 6. if no longer under warranty, seek the services of a qualified professional. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | iLO DVDRH04 DVD Recorder
Why does it keep flashing ''Loading''?
my protron dvd recorder will not power on can you tell me what to do?
Nov 18, 2008 | Protron PD-DVR100 DVD Recorder
No sound when watching TV or playing a DVD through our Philips DVDR3570H/75 DVD recorder. AUDIO is OK when watching TV with recorder switched off
I would check all cables to make sure they are connected properly and secure, also check the cables for any defects ie bent pins, frays in wiring, etc. and check all connectors on the front or back of your tv (which ever way you have it hooked up) to make sure they are not loose or damaged first. 2. I know you can connect your dvd properly, but I have to suggest it anyway, go back through the manual and make sure all settings are properly set.
3. You may need to update your firmware, which you can find instructions in pdf at this link it will be the 6th link down in pdf. I tried finding your device on the manufacturer's website, but you need the model number, I will include that link as well. Since it only 6 months old, it should still be under warranty so I would check into that as most usually have 1 year warranty. If all else fails, it might be something internal with the dvd recorder and you will have to get another one or take yours to a repair shop, but if you do take it to a repair shop make sure it is one that is reputable and trust worthy. I hope this helps you out and I am sorry I could not be more specific on the problem.
Jun 02, 2008 | Televison & Video
Tevion player shows BAD DISC,
Since the unit is under warranty, you can't touch anything without voiding the warranty. This problem could be as simple as a dirty lens. Bring the unit in for repair under warranty.
Dan
Mar 19, 2008 | Televison & Video
Darn blue loading light won't stop
The problem with these units is the filter capacitors in the power supply. They should be removed and replaced with 25 v.dc capacitors...total cost for the capacitors £5. If you don't fancy doing the repair your self, perhaps you know of a good friend who can use a soldering iron!
The capacitors are 2200 micro farads radial mounting, 680 and 1200, all should be at least 25v dc working for a reliable recorder. The existing ones are prone to "leaking" and should never have been used...shame on you JVC!
Regards,
John Saunders
Mar 11, 2008 | JVC DRM10 DVD Recorder
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
DVD Recorder/VCR combo shuts down during DVD recording
If the device is still under warranty then it is worth calling and getting a repair/replacement. If not, then go with the new unit. it sounds like the one you have was not a very good unit to begin with. make sure you read the consumer reports on new available units before buying, so as to avoid buying another lemon.
Feb 02, 2007 | JVC (DMRV1S) Burner
DVD displys "loading" constantly
First of all if it is still under warranty take it back and exchange it or have them look at it. As far as it not wanting to turn off you can search for a reset button on the back of the unit. Reset it. Or if no reset button just unplug it and plug it back in. See if that helps. As far as being jammed. Unplug the unit. Very carefully take the unit apart. See if anything has been accidentally placed in the unit when a dvd was pushed in at the same time. I have experienced this before cause I have little kids. Things happen. Now there again by taking it apart could void any warranty you may have. Also something in the unit could also shorted a circuit out causing it to not turn off.
Sep 18, 2006 | JVC DR-MV1S DVD Recorder/VCR
Constantly Loading
everything in repair is money, all depends in cost, you paid for what you get and you get what you pay for..if it cost you a lot you repair it but if was cheap dont waist you time.. I can tell you send it to JVC they will help you but how much you gona paid for it (shiping insurance and time) better check for a local tech may be is cheaper...good luck
Aug 02, 2006 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-M10SEF DVD Recorder Logo
90 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
