Question about Mitsubishi WD62327 TV
Spots on tv picture
When i watch a hockey game with a white background i have black dots on the screen i believe this is dust on the mirrors is there anyway to clean without taking off screen (is that easy to do) ie take a blower and blow it thru the vents
  • 3 Answers
I had the same problem and it is just dust. While it was still under warranty, I had it cleaned and observed how it was done and is really simple as there is only like 7 screws you need to take off. He used some high end rubbing alcohol (not the kind you buy at the pharmacy) that had a higher percentage of alcohol. He also suggested canned air but you need to be super careful as you do not want any of the liquid to come out.
You have to be uber careful as the mirrors in this TV are not like your bathroom mirrors where the reflection is on the underside of the glass. These mirrors have the reflecton on top of the glass and can be scratched super easy.
I clean mine regularly and I use the swiffer dusters, it works awesome!
Posted on Apr 19, 2009
A friend of mine had the same problem. It is dust on the mirrors, but I recommend you have it professionally cleaned. They had theirs done and it fixed the problem
Posted on Feb 07, 2008
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
How do you clean the dust out of the projector, there are particles that look like small white stars on the black areas and black stars on the white areas. Is this dust?
If you focus the image on a screen up close to the projector and notice small rectangular black and white spots, then you have pixel failures.
Jul 11, 2011 | Optoma TX542 Projector
Black spots on TV when watching sports etc that have white in the picture. The black spots are showing up on the ice for instance (Hockey) all over the TV.
I SUGGEST CLEANING THE LENS ASSEMBLY. IF YOU LOOK ON THE SIDE OF THE TV CABINET YOU WILL A SMALL SQUARE THAT IS ABOUT 4 INCHES BY 6 INCHES HELD IN WITH ONE SCREW IF YOU LOOSEN THAT SCREW YOU WILL BE ABLE TO GET INTO THE CABINET OF THE TV AND CLEAN THE LENS GOOD LUCK
Jan 06, 2011 | JVC HD-52G786 52" Rear Projection HDTV
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
I just bought a Nikon D60 on ebay,Theres a black dot in all pics
My guess is that you have a dust spot in the camera on the mirror. This is not a user fixable ptoblem unless you are very well versed on camera repair. I would take to a camera store and have them clean the mirror.
Aug 23, 2009 | Nikon D60 Digital Camera
Small red dot in center of 53" Hitachi projection tv
hi, not good news it`s probably a burn in on your red crt (picture tube), tv has to have back completely removed, which means top and bottom covers, (carefull with the top cover it`s heavier than u think, has mirror bolted to inside), turn on tv just long enough to light up all 3 crt`s to identify the red one, turn set off & look into red lens,(may need flashlight) if you see any black specks in center of tube it`s burnt and has to be replaced, be advised u will see gnats, ect. inside but your looking for specific speck, if no visible burn mark have tv man come out, otherwise it`s very pricey, hope this helps and not crt, video-tek
Jun 06, 2009 | Hitachi 53UDX10B 53" Rear Projection...
White spots on screen of my Samsung DLP TV
What causes the DMD board to go out?
No Picture, but have sound
Had a new lamp put in this morning
TV now has 2 white spots
TV - bought in 2003 for $3600.00 and only used 5 months of the year
Jan 21, 2009 | Samsung DLP HL-P5663W 56" TV
Vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
Dec 05, 2008 | Sony KP-53HS10 TV
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
