Question about Toshiba TP55F80/81 55" Rear Projection Television
Red Screen with Vertical Concave Lines
I'm thinking I have a problem with the Red Drive circuitry. Any Ideas??? If so what & where should I look since I dont have a service manual to help me.
  • 2 more comments
  • bigl31 Feb 03, 2008
    I would try but now the TV will not come on at all. You can hear the highvoltage kick-in then the power led will begin flashing. Meaning its going immediatly into protection mode. Now what short of taking it in? If I had a full service manual I probably could fix on my own. But I dont see getting one of those anytime soon.
    The set was working with just the B/G guns only when I had the circuit card pulled from the Red CRT's yoke. I put it back on last night to get a pic of the screen when it was solid red with the white lines. It showed the issue went into protection and now will not come back on at all.
    I've found the abbv. version but I would put money on it that I'll need the full one. Thanks For Helping me!!
    I found this one but I dont know if its for mine & its a training manual.
    http://www.tacpservice.toshiba.com/TACP/...
    I thought so. But there sure is alot of similarities in that manual. It even list the TV model number on page 6 at the top.
  • Toshiba Master
  • 8,617 Answers
Check the transistors and resistors on the CRT socket circuit board itself. Also try turning down the red drive a little this may eliminate the lines.
Posted on Feb 02, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Feb 03, 2008
    I will try to locate a servicemanual for you.
  • Sonny Berry
    youre welcome. I have some good sources for manuals. I should be able to locate one.
  • Sonny Berry
    No thats for a different chassis. yours is the TAC9676 chassis
    I am still checking for ou. But the 9676 is your chassis for sure.
  • Sonny Berry
    They are similar but not exact.
Toshiba TP55F81 going into protection mode
Sir,
Since you have recently purchased that TV... It is best to return it have it changed with a new one... It has still a warranty, right? So why give yourself a problem... It is your right as a customer to get satisfied with what was bought. Remember you pay them for that... Exercise your right!
Go!
Feb 01, 2008 | Televison & Video
I have a 2006 RCA model R52WH73. The horazonal lines suddenly went to being concave lines and now you see a double image.
horizontal circuit problem .. vertical double image or horizontal.. check screen voltage and focus setting on board. CAUTION: EXTREME HIGH VOLTAGE. QUALIFIED SERVICE PERSONELL ONLY .. serioius high voltage..
Dec 15, 2009 | RCA Televison & Video
Vertical lines on the laptop screen
hi, the fault could be cause by a number of things, the Lcd harness cable maybe loose or faulty or even a mainboard issue, but it sounds like the matrix (circuitry)of the LCD is on it's way out.
Feb 28, 2009 | Compaq Presario M2000 Notebook
The red blue and green lines are at the top of the screen, the colors are out of focus and the picture seems concave. the menu has a convergence label,but it does not appear on the screen
The supply for the convergance circuitry is off the flyback (high voltage) transformer. There are three fuses to the direct right of the transformer. One of these is probably open. Also re-solder or replace the rectifier diode off the blown fuse. This should solve your problem.
Dec 05, 2008 | RCA Televison & Video
Rca 61130 rear projection tv has pink haze
Try adjusting your Red screen control down just a little. This is usually a sign of the red crt developing a short. Often just turning the Red drive down just a bit will make the retrace lines disappear if not you will eventually need a new CRT or repairs in the red drive circuitry. Hope this helps.
Jan 26, 2008 | Televison & Video
White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Eric
Dec 31, 2007 | JVC Everio GZ-MG130 Camcorder
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Aug 16, 2006 | Samsung PPM50H2 50 in. Plasma Television
Concave screen problem also
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
Jun 08, 2006 | Compaq fs740 17" CRT Monitor
Televison & Video Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
