Question about Dryers
FRIGIDAIRE DRYER I have a Frigidaire Dryer that is running but not producing heat. I looked for the fuses but could not locate. Can you please tell me where the fuses are located?
I don't know what you mean when you ask about fuses since a blown fuse would stop power to the dryer, but I do know a common reason for a dryer to run and not produce sufficient heat is that it may be cycling on the "safety" thermostat. One common reason for this is that the "cycling" thermostat (which is the thermostat which the dryer should cycle on), located in the exaust air stream, is insulated with collected lint, which also lowers the air flow through the ducts. You may just need to thoroughly clean the accumulated lint. I would suggest buying the service manual for your dryer, if available, and go to the manuals troubleshooting guide.
A test for cycling on the safety thermostat is to run the dryer with a damp load and watch the flame through the small service door at the bottom of the dryer; if the flame stars cycling on and off every, say 15 to 30 seconds, then the dryer is cycling on the saftey thermostat, if the flame repeatedly burns for close to a minute or longer, than that is not the problem.
Posted on Feb 02, 2008
6ya staff
SOURCE:
Where are fuses located in Frigidaire front loading dryer?
No fuses. Probably Heating element or one of the thermal switches. Electric dryer I am assuming
May 24, 2015 | Frigidaire Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2012 | Frigidaire Dryers
Frigidaire model FEE332ESO dryer drum turns but no heat
Your problem is probably thermostats and not fuses.
They look like flying saucers and should click when you push in the metal discs
Nov 07, 2009 | Washing Machines
Frigidaire dryer AEQ7000EGO not heating up
you need to make sure you are getting 220, your dryer will run on 120 but not heat.
2nd check fuse that is located inside dryer near drum
3rd check heat elements for breaks.
Sep 12, 2009 | Frigidaire AEQ7000ES Dryer
I'm looking for the two house fuses mentioned in the trouble shooting section of the dryer manual; runs but wont heat. MODEL # is FEQB400FSI
they should be in you fuse panel in the house .how ever you can check the heating element and the thermal fuses located in the cabinet of the dryer
Sep 05, 2009 | Frigidaire FEQ1442ES Electric Dryer
Hello, My gas dryer FRIGIDAIRE with model
check exhaust ducts and inside bad of machine for lint blockage over heat shuts down heat if not igniter or gas valve failure likely
Jul 06, 2009 | Dryers
Where can I locate the blown fuse/s of a frigidaire dryer?
There are no user servicable fuses in the machine, I believe they are talking about your breaker box.
A 220 dryer requires two 110 volt circuits to run the 220 volt heater
The motor and control circuits only require 110 and are run from only one of these two lines. If the other line blows the dryer will still run but there will be no heat.
Good Luck
Quentin
Jul 06, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
229 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
