Question about Motorola Mobility RAZR V3
Keypad Problem How can I get the keypad to light up? It won't light up when we open or dial. Any help is greatly appreciated. Thanks1
  • LuciLu Feb 02, 2008
    Thanks for your suggestion re the sensor. The sensor on the V3 was covered by a small silver strip. I couldn't locate the battery life so I removed the battery and looked where you suggested the sensor would be. I removed a small silver strip, hopefully I haven't ruined anything but at least the keypad lights up now. Thanks so much!
  • 2,130 Answers
Have you tried it in the dark? There is a photo sensor that is located just above the right soft-key. It looks like a pin hole. Put your thumb over the hole and press a key on the keypad, you should see the keys light up. The purpose of this sensor is to prolong the battery life by not having to light up the keypad in the daylight.
There is a way to disable the photo sensor so that the keypad is on whether it is day or night. Look for a setting that allows you to turn the "battery saver" feature off.
- Jim
Posted on Feb 02, 2008
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Number pad buttons dead
keypad contact, open the phone then clean the contacts using a regular pensil eraser, on the keypad, try to brush out the dust using a toothbrush or a small PC vacum cleaner
good luck
Jul 28, 2008 | Samsung T509 Cellular Phone
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
My keypad won't light up when door is locked whe you push lock won't light up green
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
Harris TS22 keypad problem
Try and Get the Unit tore down to where you can look at the bottom of the keypad. you may have water or something between the board and keypad. I recommend cleaning with isopropal alcohol and q tips. See if that gets you any where
Jul 09, 2009 | Fluke Networks TS22A Test Set With Speaker...
Keypad for chamberlin garage door opener stopped working
You need to reprogram the keypad. Press and release the learn button on the back of the motor. Within 20 seconds, press your four digit code into the keypad and press and hold the enter button until the lightbulb on the motor blinks once. You are finished.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
RAZr V3 Keypad lighting not working
Settings, Initial Setup,Backlight. Try this. Hope it works.
Nov 02, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
135 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
