Question about Baby Gear
Check engine light on
Had a code p0073 what does this mean
  • cowboy101 Feb 02, 2008
    jc2it thank you for getting back to me on the poo73 engine code, would you know where that sensor is located, or do you know of any sites that i can go to that can show me these typs of things, i realy appreciate your help.DUANE
    Scholar:
  • 58 Answers
According to the chrysler "tech connect" tech. help website, P0073 is Ambient air temp sensor high. Likely cause is the sensor itself.
Posted on Feb 02, 2008
Engine light is on with the code p0071 and p0073 and it coincides with outside temperature indicator. It fails all the time showing me weird temps this morning I've found the sensor hanging out.
You should replace the sensor and re-attach it properly. The engine ECM uses outside air temperature to adjust the fuel mapping on an engine. The codes you have are for the fuel to air ratio which has everything to do with the fuel mapping of an engine. Hope this helps
Mar 27, 2017 | Cars & Trucks
How to fix 2006 jeep wrangler p0073
Code 73 means the signal coming from the air temp sensor is too high. Could be the sensor or a short in the wiring.
You may need a shop manual to get the testing procedures.
Sep 01, 2014 | 2006 Jeep Wrangler 4.0
P0073 CODE
ambiant air temp sensor is probaly broken or disconected it should be in the front bumper small black plastic with 2 wiers looks like a pencil tip
Feb 14, 2014 | 2006 Chrysler 300
Dodge neon 2005 engine code P0073
Hi
That is the 'ambient temp sensor high' code.
Read this: LINK
Td
Oct 24, 2012 | 2005 Dodge Neon SXT
P0073
Per Google search:
This code means ambient air temperature sensor circuit high.
Source: http://engine-codes.com/p0073_dodge.html
Aug 24, 2012 | 2004 Dodge Ram 3500
What do the codes p0072 and p0073 mean on my 2008 Dodge avenger? w
Well, I would say that it means that SOMEBODY is confused!
Diagnostic Test Code (DTC) P0072 is defined by SAE J2012 as "Ambient Air Temperature Sensor Circuit Low" DTC P0073 is defined as "Ambient Air Temperature Sensor Circuit High"
I do not know how the ambient air temperature sensor circuit could be faulted both HIGH and LOW at the same time.
The only thing I have ever seen cause something like this is when people try to install aftermarket "performance chips" on their vehicles which "lie" to the computer about what the ambient air temperature is.
Apr 23, 2012 | 2008 Dodge Avenger
P0073
P0073 is actually for the "Ambient air temp sensor high" which is likely to be the sensor itself, or possibly the wiring for it.
you will need to test the unit with an Ohm meter (disconnected from the wiring harness, engine OFF) at different temperatures to see if you get a good reading on it.
Mar 02, 2012 | Cars & Trucks
What is the signal 0073 means and what is the sulotion {dodge
What signal is this? is this for a check engine light code?Okay i know what you mean, it a p0073 code, this is the ambeint temp sensor,this is the sensor that tells you the outside temp on your display, the sensor may be bad ,misssing or bad wire going to sensor,was this van in a crash, lots of times the sensor gets damaged from an accident,
Jun 01, 2010 | 2005 Dodge Caravan
Baby Gear Logo
495 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
