Question about Ecoquest Flair Air Purifier
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
  • Anonymous Jul 31, 2008
    MY FLAIR FAN MOTOR DOES NOT WORK...MY HUSBAND SAID HE COULD INSTALL IT IF WE COULD FIND OUT WHERE TO BUY THE PART.
    ALL THE PARTS THAT SEEM TO BE AVAILABLE ARE FOR NEWER STYLE PURIFICATION SYSTEMS.
    NOT THE FLAIR.
    BOBBIGO
  • JP Rohrer Sep 24, 2008
    Our unit is just sitting there--no noise, no fan turning. Ours is only a couple years old at the most.
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Posted on Nov 13, 2008
How do you clean motor on Flair? Fan will not turn
The motor shouldn't need cleaning that would prevent it from turning on. When was the last time you cleaned the machine?
Jul 26, 2011 | Ecoquest Flair Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
I have the Flair Air Purifier. Everything except the light seems to be working. When i push the button, the fan jumps into high mode for a couple of hours as it is supposed to, but I don't notice any...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse just for the ozone part it is marked F21 on the same board, it is soldered in the board, it is a black round fuse marked 400ma 250v on some models
Aug 21, 2010 | Ecoquest Flair Air Purifier
Can feel motor run, but fan doesn't turn and very little ozone smell-have new plate
same deal with mine. Im gonna open er up n give a look c. Im thinkin the fan motor is running but not enough 2 turn the blades. Im fixin 2 google fan motors now as a matter of fact.
Jun 09, 2010 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
How do we clean the fan on our Flair?
take the grill of and get a soft cloth and lubricate the center of the motor
Mar 17, 2010 | Ecoquest Flair Air Purifier
Ecoquest flair fan replacement. Cannot read the model # on fan.
I can help you get a replacement fan for your flair if you still have not found one. You can reach me at stevelam@ecobusiness.com.
Oct 12, 2009 | Ecoquest Breeze AT Living Air Purifier
The fan makes noise when turning
It probably need oiling. The fan motor should be oiled at least every two months. For complete cleaning instructions (including oiling) e-mail to miller@healthyti.com. Ask for their free cleaning instructions. They will be glad to help.
Jun 25, 2009 | Ecoquest Flair Air Purifier
Fan trouble with Flair
remove the retaining screw from the bottom of the unit and slide the insides out the back. use WD40 with the plastic extension tube, spray into the motor armature/stator and turn with your hand until it is free spinning then reassemble and turn on.
this is an ongoing problem with my unit because the air and all contaminents are pulled directly to the fan.
Apr 04, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
306 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
