Question about Sunbeam 2366 MixMaster Series Hand/Stand Mixer
Sunbeam 275 watt 2366 mixer
Motor does not come on I think it was overloaded. could it be the circuitboard? the windings do not look burned nor do they smell burned.
  • 1 more comment
  • schlebit Dec 05, 2008
    I have the same problem , what can be the cause ?
  • dwedll Jan 05, 2009
    Need a circuit board for 2366 sunbeam 275 mixmaster do you know where i can get one. dwedll@hotmail.com
  • Anonymous Jan 27, 2009
    I HAVE OPEN IT AND FOUD ONE CIRCUIT IS BURNON CIRCUIT BOARD.WHEN I TRYTO CONNCT THE WIRE DIRECT IT RUNS SO PROBLES CIRCUIT BOARD. WHERE CAN I GET THE NEW BOARD OR REPAIR THIS ONE.
I don't know if this is ok but I have a 2366 mixer that works with no base. Anyway I could buy your base? bjdg1@hotmail.com
Posted on Jun 17, 2009
Where do i get the fuse for the mixer
Posted on Dec 27, 2008
It is probably the swich /pot combination on the electronic board. The shaft on the unit I have had twisted off and would no longer turn the switch on or off.
Posted on Dec 26, 2008
Can on overheated mixer be fixed
take it in to an appliance repair shop for a diagnosis
generally if the motor over heats , it burns the field windings and the fix is a new motor
the motor and repair cost is close to a new unit but you will get that information when you get the diagnosis and quote
Dec 23, 2016 | Sunbeam Food Mixers
The motor in my mixer is not working. I have had several years and just recently retired and started using. how can I tell is it is a rebuilt mixer. tag on bottom - 050805318. Box says 150 watts
dust of baking powder can give (dirt) over time in microswitch or switches and also the carbon brushes of the motor , cleaning and measure the electric is the point.
overload and burned collector is interrupted in the motor armature or one of the two coils of the field winding. in the latter case, a cable break.
Apr 01, 2016 | Emerson 120 Watts EM82821 Hand Mixer
Mixer on my Sunbeam Model MX5900 compact mixmaster has burned out because beaters kept jambing in each other. Can I purchase just the mixer and beaters? Stand and bowl are OK
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
Sep 20, 2011 | Sunbeam Food Mixers
I have a mix master 2366 275 watt my daughter was making cookies and it just stopped working.It is only a couple years old
it may be that the Solid State Speed Control has gone bad did any smoke or bad odors come out of the mixers but if you have any warranty period left then they will gladly fix it
Jan 02, 2011 | Sunbeam 275 Watts 2367 MixMaster Series...
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Mixmaster motor won't spin. Leads from circuit board to motor read 119 volts at the motor. voltage does not vary when speed knob is rotated but does turn off & on. 275 W sunbeam mixmaster, white...
so far I determined the thermal fuse had blown. I jumped around it but can get replacement. Now the motor runs full speed when turned on. I suspect the pot turned by the speed knob is bad. Having trouble locating a replacement circuit board.
Jan 19, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Hello, I have sunbeam mixer model #2360 and had one large and one small turntable. I lost the large turntable and am unable to locate a site to purchase another one. Can you please help? Thanks, so much!
Sunbeam 2386 Sunbeam 2386 MixMaster Series 275 Watts Stand Mixer. Overall User Rating. 3.0. out of 5 ... 2386 Reviews & Articles. Sunbeam - Small Appliance Parts ... retrevo.com/s/Sunbeam-2386-review-manual/id/952ci071/t/1-2
Good luck_Ned_
Nov 03, 2009 | Sunbeam 2386 MixMaster Series Stand Mixer
Wooden spoon killed the motor!
these mixers use an electronic triac(to vary the speed of the mixer) of such low amperage that they run hot normally(to wear OUT), and they don't fuse the units electronics or motor anymore so anything that binds them will short out the triac or motor winding(from heat) and make them inoperable,try and order(what they call) an internal electronic part from these companies and good luck, I tried for 3 months and told them what I needed,they agreed this part was defective, but they wont sell you an internal part(LIABILITY ISSUE) unless your a "company certified technician" go figure, I finally got one through N.T.E.semi-conductors. and my customers HAPPY NOW!!!
Oct 06, 2009 | Sunbeam 2366 MixMaster Series Hand/Stand...
I have a Sunbeam Mixmaster Model 2366. The motor
Still have it? If yes, please e-mail me at rgr04@yahoo.com
Jul 12, 2009 | Sunbeam Food Mixers
Model #2366 mixer blade release problem
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
Oct 08, 2007 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam 2366 MixMaster Series Hand/Stand Mixer Logo
488 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
