Hard Drives
Problem for Hard Drives
Generic problem for all Hard Drives
Windows xp drivers for seagate ST3...
By skalin88 on Feb 02, 2008
WIN XP states there are no drivers installed for my external hard drive. It has been working fine until now. I have done any system updates and on seagate support it states there are no drivers needed. any suggestions
thanks
sam
Same Problem
Jan 29, 2009
-   My LACIE 320GB Desktop hard disk was working fine but now when I plug it in; it will not get come up (was on the 'F'port) note if i put a memmoy stick in, it comes up ok on the 'F' port.-   Tank1427
Best Solution
posted on Feb 02, 2008
Helpful)
quarryswr
Rank: Wiz
Rating: 88%, 59 votes
Drivers are not needed for this Ext HDD.
If you go to your Computer Management>Storage Devices,you will have to assign a Drive letter for it to show in your "My Computer" as a External Hard Drive.
Also ensure that drive is set as "slave" and do not connect until computer is booted to Desktop.
All changes will take effect after reboot.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
Benimur
Rank: Guru
Rating: 88%, 3799 votes
To my knowledge too, there are no drivers required for an external hard drive.
If your PC displays the message as you have posted, it can only indicate that:
1. The USB interface of the external HD enclosure is detected, but
2. The actual hard disk inside the external HD enclosure is not detected.
Which can only mean that it is a hardware problem and that your external HD may be defective.
This can be confirmed by physically removing the HD inside the enclosure of the external casing and mounting it internally to a desktop PC as a Primary Slave or Secondary Master/Slave (as applicable) and running your CMOS/BIOS to autodetect. If it can be detected, proceed booting to your OS and run diagnostics or utilities to determine hard drive health.
hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Was this helpful?
Yes
No
Popular Solutions for Hard Drives
Questions and Unsolved Problems for Hard Drives
Answer
My Dane-Elec so Ready 500GB USB drive has been cleared by a 3rd party drive copy program, I now... (More)
Answer
i purchase a kingston 32 GB pen drive but when i store data in it it currrupt or not working how i... (More)
Answer
I have a Seagate Freeagent 1.5TB hard drive. One day I left in a hurry and I forgot to disconnect my... (More)
Answer
I had the Cruzer micro plugged into my comp when i looked and noticed that it wasnt lit up anymore.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
