Question about InFocus LP725 and LP735 Replacement Projector Lamp - SP-LAMP-LP7E Projector Lamp
InFocus LP725 light goes out after 10 minutes
Hi. I have an InFocus LP725 projector that works fine for 10 minutes into a presentation but then the light goes out. Let it cool down for awhile and it will light again.  Is there some type of thermal switch built into these that causes it to shut down when it gets too hot.  We bought a replacement lamp for it from a source other than InFocus and now I'm wondering if it might be a higher wattage than the original.  By the way, I did check the fan filter and it was clean, the fan works fine and is unobstructed.  Any suggestion would be appreciated!  Thanks Steve
    Scholar:
  • 58 Answers
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Posted on Feb 02, 2008
InFocus IN2102EP Projector My projector is connected to an Elmo TT-02s digital presenter that I use to show documents to my Students. When I first power on both devices, they seem to be working fine then...
Most projectors have an auto search function which can be switched off. You can then set the source to the specific input that you are using. Of the problem persists it may be the battery of the Elmo. (If it has one) Maybe it isn't strong enough to send the signal and maintain it.
Good luck.
Aug 05, 2011 | InFocus IN2102EP Projector
Projector Works for one minute then the lamp goes out.
sounds like a fan not working or a bad power supply/ballast. If it is a fan that is not working it will cause it to shut down. That would either be a bad fan or bad main board. But, if all fans are working, most likely it's the power supply/ballast.
May 10, 2010 | InFocus IN36 Projector
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Jun 16, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP725
Hi there
Resetting the unit will unfortunatelly not work , you are facing replacing or repairing the Projector's Mainboard.
Quite expensive to do
Mar 13, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
Infocus LP725 projector
May 25, 2007 | InFocus LP725 and LP735 Replacement...
407 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
